S-Works SL 2018
How come these colorways are not available in the US? :/CrankAddictsRich wrote: ↑Thu Feb 22, 2018 1:50 amhere's a link to the Thailand Specialized website... the colorway is called Monocoat black/white reflective
https://www.specialized.com/th/en/mens- ... 643-153988
- Contact:
Specialized determines that some color ways will sell better than others in certain markets and they distribute them accordingly.DCcyclist wrote: ↑Mon Feb 26, 2018 7:34 pmHow come these colorways are not available in the US? :/CrankAddictsRich wrote: ↑Thu Feb 22, 2018 1:50 amhere's a link to the Thailand Specialized website... the colorway is called Monocoat black/white reflective
It's nothing new... every year there some colors offered in some areas that aren't offered in others. I remember a few years back, 2015 maybe, they had a non S-Works Venge in the OmegaPharma colors that was offered in Canada. There was also the Booned "Dragon" S-Works Venge that was offered in the Asian market.
Every year they do test colors that the employees at Specialized get to. Sometimes they also come up for sale too.
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
http://www.skratchlabs.com
2015 Specialized S-Works Allez
2015 Specialized Venge Pro
2014 Specialized S-Works Shiv TT
Thank you. Wish they had some of these colorways in the US. Is it even possible to order a non-US frameset thru a dealer?CrankAddictsRich wrote: ↑Mon Feb 26, 2018 8:18 pmSpecialized determines that some color ways will sell better than others in certain markets and they distribute them accordingly.DCcyclist wrote: ↑Mon Feb 26, 2018 7:34 pmHow come these colorways are not available in the US? :/CrankAddictsRich wrote: ↑Thu Feb 22, 2018 1:50 amhere's a link to the Thailand Specialized website... the colorway is called Monocoat black/white reflective
- Contact:
No... I don't beleive so. I have two friends that both wanted the OmegaPharma Venge frames that I mentioned earlier. They drove up to Canada to get them. I don't beleive that US stores will cover the warranty issues if you do this though. Not sure.
- Contact:
Can anyone quote me the weights of the standard S-Works Tarmac vs. the Tarmac Pro, for frame only... same size. I'm just trying to get a sense of what the weight difference is bewteen the two levels... I know in previous models it was usually 100-150g difference.
Someone posted a 56cm Tarmac Expert frame (same as the Pro) as 924g, I believe with hanger. The S-Works I've seen everything from 780-908g here.CrankAddictsRich wrote: ↑Thu Mar 01, 2018 2:05 amCan anyone quote me the weights of the standard S-Works Tarmac vs. the Tarmac Pro, for frame only... same size. I'm just trying to get a sense of what the weight difference is bewteen the two levels... I know in previous models it was usually 100-150g difference.
Some more weights for the database. Sagan Superstar in size 56cm - frame with seat binder, cage bolts, brake bridge, bb cover 919g; fork 350g uncut; seatpost 175g. Not the lightest Sagan on here but I'm happy enough.
Lots of little grommets etc but no parts list or appliance notes from Spesh. Hated the F8 I had for a season but at least Pina did provide clear instructions which parts were used for mechanical, Di2 or EPS. Anyhow I've mostly figured the bits I need except which little plug/grommet or whatever it's called is required where the rear brake cable and electronic cable enter the top tube. Any photos or heads up would be appreciated. Ta.
Belgian Flag S-Works Tarmac viewtopic.php?f=10&t=144553
- Contact:
I'm pretty sure that the tier 1 shops now have the SL6 Disc frames... StrictlyBicycles is showing what's clearly a disc brake tarmac with a cardborard cover over the brake area that says "no pictures please" on their instagram. They typically get bikes on the day they're released.
https://www.instagram.com/p/Bf5_bV_nsnG ... onstrictly
My LBS has asked Spesh about this and didn't get a definite answer. Consensus seems to be 6.2Nm based on this being what all their other clamps are marked with.
Chiming in late.flafonta wrote: ↑Sun Sep 03, 2017 9:33 pmHere is mine. Still a work in progress, dialing the fit and need to cut steerer tube. The Zipp logo on the stem is also screaming and the Power saddle is great for my a$$ but does not look great.
Maiden voyage this morning. Felt good, lighter, easier to toss around. Out of the saddle effort felt great, Feels lower than my 1st gen Venge. And dead silent.
Now with picture, hopefully it will work this time.
That bike looks sick!!!!
Wowzers!flafonta wrote: ↑Sun Sep 03, 2017 9:33 pmHere is mine. Still a work in progress, dialing the fit and need to cut steerer tube. The Zipp logo on the stem is also screaming and the Power saddle is great for my a$$ but does not look great.
I actually came here this morning to ask this very question, as my Pro started creaking last week. My SL5, even with super-long service lengths to the BB, has never creaked once in 30,000 miles.
- Similar Topics
- Replies
- Views
- Last post
- 523 Replies
- 84598 Views
Last post by CrankAddictsRich
Thu Apr 19, 2018 12:04 pm
- 5 Replies
- 1638 Views
Last post by Vandit
Fri Nov 10, 2017 7:50 pm
- 35 Replies
- 4507 Views
Last post by slowK
Tue Apr 17, 2018 2:37 pm
- 11 Replies
- 1179 Views
Last post by REGICYCLE
Sun Mar 04, 2018 11:09 am
- 7 Replies
- 2927 Views
Last post by TobinHatesYou
Mon Aug 28, 2017 7:01 am
