How to remove Reynolds freehub Strike SLG wheelset?
poppiholla
by poppiholla
Can somebody help me out? Thanks
I also need the correct installation of a Campa Freehub on the Strike SLG rear wheel.
Specialized Tarmac S-works SL7 (Satin carbon spectraflair tint)
Specialized Tarmac S-works SL6 (Green Cameleon)
Specialized Tarmac Pro SL6 Disc (Blue/Teal Sram Force AXS)
Specialized Epic Elite 29
Greetings from the Netherlands
Attermann
by Attermann
just need hex type wrenches, and loosen the end caps, if the oppisite side comes loose, then just insert a bigger hex.
poppiholla
by poppiholla
Thanks. Do you know how to install a Reynolds freehub body. I bought a campa freehub body and it came with dustcover and small ring.
I assume that I have to mount the dustcover and then slide the new freehub body over the axle. What to do with the small spacer/ring?
Is it ok to hand tighten the endcaps? when I use two 5mm allen keys the end caps are tightened to firm and the freehub body won't spin/turn?
Attermann
by Attermann
The small spacer needs to be between the freewheel and the bearing
poppiholla
by poppiholla
Do you mean that I need to slide the spacer over the axle first and after that I slide the freehub body over the spacer?
poppiholla
by poppiholla
Topic can be closed. Problem solved. The small washer did the trick.
Verzonden vanaf mijn iPhone met Tapatalk
