sram red etap HRD availability..
We need some unboxing photos right here... anyone?
Got my eTap HRD kit from Bikeshop.no yesterday.
Everything as expected except that two SRAM/Avid 160mm discs came with it.
(The entire kit has SRAM ID 003018164008).
Only uploaded photos of the shifters, calipers and the (surprise disc), kit also includes derailleurs, charger and the mysterious USB dongle for FW upgrade.
Also included were caliper bolts, bleeding block and extra hose barb & /compression nut ("olive").
Going to be busy next few days in upgrading my bike
Congratulations!
Now actual weight please...
- Gearjunkie
Thanks for posting the pics.
Forgive me please if this has already been discussed, but it's interesting that the Etap HRD hoods aren't huge like the Sram Red Hydro hoods are. Presumably it's because there is more space in an Etap hood than mechanical but on the other hand Shimano seem to have dealt with it ok in the new DA...
Gearjunkie wrote:Thanks for posting the pics.
Maybe it's the Contact Point Adjustment that DA9170 is lacking.
Then I've put the componentes on my 0-500g scale, should be pretty accurate. Removed removable plastic inserts, no mounting hw included (bolts etc.).
Did not remove the warning labels, should be 0,2-0,5 g (??)
Attached the Li-Ion batteries to the derailleurs. The caliper/shifter "systems" are as they came out of the box, completely functional/bled with brake fluid, brake pads and CR2032 battery.
The weights were:
Shifter/front brake caliper: 360,3g
Shifter/rear brake caliper: 377,5g
Front derailleur w/battery: 159,5g
Rear derailleur (Wi-Fli) w/battery: 243,1g
Battery: 24,0g
I've made every precaution for accurate weighings, especially making sure no part of the component touching anything but the scale plate.
The cut-outs on the photos are to minimize file size (and remove messy details on my bike work desk!)
The weights were:
Battery: 24,0g
jlok wrote:Gearjunkie wrote:Thanks for posting the pics.
Isn't it the same thing as Free stroke adjustment on ST-R9170?
Anyone heard anything regarding an etap clutched rear mech?
Thank you Woods bring us good news!
Any pic of the completed bike?? How's the brake levers feel??
