Venge VIas disc actual weights?
thumper88
by thumper88
Has anyone actually put an S-works or Pro version on the scales yet?
Besides the specialized marketing team, I mean?
There are various numbers out there, from the improbable specialized claim that the bike can be built to hit 15.4 lbs and what they called the s-works version with di2 was at 17.1 (though they don't actually sell a di2 s-works version).
There's talk of 8 kg in the Sagan disc thread, and I've been told by a dealer who built one that a pro with ultegra di2 came in close to 19 lbs, but he was vague, maybe intentionally. So that's quite a range, though of course that's also a broad range of builds.
Spez
by Spez
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=142990
8,1 as shown in 54. Weight it at LBS, no picture alas.
mile2424
by mile2424
Almost positive the lightweight sub 16 lb spesh was speaking of is if you you were to use lightweight tubular wheels, and a lightweight stem and and bar combo (not the Vias bar and stem), and I haven't seen many of them being built without the stock stem and bar combo.
thumper88
by thumper88
mile2424 wrote:Almost positive the lightweight sub 16 lb spesh was speaking of is if you you were to use lightweight tubular wheels, and a lightweight stem and and bar combo (not the Vias bar and stem), and I haven't seen many of them being built without the stock stem and bar combo.
Yep, that sounds about right. based on the 18.1 I can get it down to just over 16 3/4 by swapping in 9170 shifters, calipers and rotors, an ax lightness saddle, and a couple of other tweaks. having to go to an 86 gram saddle to get to 16.75 seems like a bit far.
Saw you put the McLaren up, why did you decide it was time?
soonyoung
by soonyoung
Oh it's somewhat heavy... Because of its stiffness?
bas
by bas
Has anyone actually weighed the Vias integrated stem? Wondering how much weight you can actually save and therefore its its worth sacrificing the clean no cable look. Id probably run the Aerofly bar regardless as i quite like it.
Thanks!
lovemyway
by lovemyway
bas wrote:
Fri Jan 05, 2018 1:25 am
Thanks!
The 115mm stem with stem cap, bolts and shims weighs 298g, it's pretty heavy.
prebsy
by prebsy
Also the vias aerofly is different, and much cheaper, than a normal aerofly that you'd use w/ a non vias stem. Just guessing but based on the lower price and proprietary mounting system the vias aerofly is heavier.
Bredepetersen
by Bredepetersen
I have a 56 cm vias that weighs 16.8-16.9 lbs with quarq zero pm, set up tubeless.
stormur
by stormur
soonyoung wrote:
Tue Jan 31, 2017 3:01 am
rather "aeroness". Aero frames are not "stiff" per se.
Mark Twain
bas
by bas
I have the rim Vias, its super stiff. Thanks for the info and also interesting about the bars, assumed they were the same except for the cable hole.
dvq
by dvq
I have a 2018 Venge Vias Disc with eTap ENVE 5.6s and a quarq dzero and it comes in at 18.6 lbs with dura ace pedals, computer mount, and bottle cages.
If you want some frameset weights:
54cm frame with derailleur hanger and bottom bracket installed: 1218g
Uncut fork: 439g
Seatpost with carbon rail hardware: 215g
MRM
by MRM
Utterly gorgeous dvq, but quite heavy. Wonder what it would weigh in the Fact 12r carbon of the new Tarmac. Think the paint adds quite some weight as well.
Regardless, I love it!
spdntrxi
by spdntrxi
beautiful fat chick... I'd still ride it.. one of the best looking Vias I've seen to date
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
endershan
by endershan
7.77kg for mine, with R9100 pedals, bottle cages and Rotor garmin mount.
