It is currently Wed Oct 18, 2017 3:10 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
 Post subject: THM Fibula - Need Advice
PostPosted: Mon Jan 16, 2017 1:04 am
Just bought a brand new set of the recently discontinued Fibula's and ran into some issues.
Can't get the lock-washer into the "unthreaded" section of the securing screw...
Even tried to see if I cold pass it through my C60 fork and yet again, the unthreaded section is too wide that it won't slip in...
Have tried reaching out to THM but wonder if any guys on this forum have encountered the same issue?
There is no other way of guarding oneself against flattery than by letting men understand that they will not offend you by speaking the truth; but when everyone can tell you the truth, you lose their respect.
PostPosted: Mon Jan 16, 2017 1:11 am
Hmmm...that's unusual. I've been using Fibulas on several bikes for 7 years without a single issue with fitment and function/performance. The washers won't slip through either front or rear caliper?
PostPosted: Mon Jan 16, 2017 1:28 am
Having issues with only the front caliper as the longer securing screw is only partially while the rear is fully threaded..it certainly seems that its not an issue with the washer as I tried both and neither fit. I even tried using the securing bolt to apply some pressure to the washer through the unthreaded bit but didn't budge.
PostPosted: Mon Jan 16, 2017 2:19 am
Try another washer then, any shop should have one, albeit in steel.
Then contact THM (or 3T) to see if they can send a replacement ti one.
But if it were me I'd just get out a round file.
PostPosted: Mon Jan 16, 2017 2:56 am
Resident Pro
Take out washer. Drexel with sander and good to go
PostPosted: Mon Jan 16, 2017 3:07 am
@UpFromOne, wish it were that simple.. I don't think its an issue with the washer but more of the fact that the diameter of the unthreaded portion of the fixing screw is too large that I can't even insert it into to fork.. I'll try to see if i can get the calipers into my old RXR because I don't want to forcefully jam this into my c60 fork.
@Mike, wish I had a sander.. so rather than having to make my own adjustments to a new, high end caliper, I'd rather take other measures that are a little bit less extreme.. :mrgreen:
PostPosted: Mon Jan 16, 2017 5:36 am
Do you have a caliper? If you can get the measurements I can take mine off and tell you what mine is.
Strava
Current Stable. The Snob Machine | The Crumpton
The Ex's. LS Siena: 6.21kg | Parlee Z5 SLi: 5.9kg | LS Xicon: 5.76kg | C59: 5.7kg | Cervelo R5ca: 5.09kg | Fuji Altamira SE - 6.2kg | Scott Foil - 6.2kg | Evo - 5.18kg | LS Classic - 6.7kg
PostPosted: Mon Jan 16, 2017 5:57 am
Yeah, let me try to get a reply from THM first (already sent them an email) and see what they say.. I have the calipers in the box so its easy have them measured.. Just need to find a measuring tool, thats all.
PostPosted: Mon Jan 16, 2017 6:36 pm
IIRC, i didn't have any star washers with mine.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Mon Jan 16, 2017 7:43 pm
Emery cloth will sand the fat unthreaded portion down very quickly. Then the lock washer will fit and it will go into the fork. Plumbers use emery cloth to sand copper pipe before soldering. Go to your local hardware store and buy some. Or get a piece of fine sandpaper. 220, 320, 400 grit. That will work too. Emery cloth is cloth backed so will last better for rough sanding metal. Sandpaper is of course paper backed. Less tough. Good for wood, not metal.
PostPosted: Mon Jan 16, 2017 7:49 pm
Is there a lot of paint around the hole? Could be obstructing things.
PostPosted: Tue Jan 17, 2017 12:57 am
@Kode, maybe this will be a good opportunity for you to reach out to THM too...
http://www.thm-carbones.com/manuals_fibula_de.html?file=tl_files/content/download/manuals/en/THM%20Fibula_3_en_WEB.pdf
@RussellS, nah.. want to try avoiding making any "structural" changes to the calipers in order to avoid something that will have THM refusing an exchange if necessary.
Update: After a bit of head scratching, I tried to pass the securing screw through my old Time RXR, and VOILA, had fit like a glove.. which means it must be an compatibility issue with my C60.. As far as the washer, I was successfully able to get the washer in by greasing the inner ring followed by screwing in the securing bolt to add some pressure in forcing it in.. It popped right in so I guess there may have been some excess material lifted by the threading process.
Now, just a matter of getting this to fit inside the c60 fork.. I guess some grease and patience will do the trick..
PostPosted: Tue Jan 17, 2017 1:04 am
Does the threaded part at least fit into the hole on your C60 fork? If so, then I think I'd be inclined to share @Russianbear's thought about there just being some excess paint in the hole etc., making it a little tight. Sounds like it might be a combination of the brake bolt shaft being very slightly oversized (since the washer itself seemed tight) and when combined with a little extra paint in the hole makes the whole thing seems excessively tight.
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Tue Jan 17, 2017 1:56 am
@Calnago, you night have a good point there.. the threaded section of the calipers fits into the fork with plenty of room to to spare.. but then again, the non-threaded portion of the caliper slipped into my RXR like a glove so the C60 must have used a lot of paint? There isn't any paint around the hole at the front end of the fork but that may not mean that there isn't any paint "inside" the hole..
PostPosted: Tue Jan 17, 2017 5:15 pm
From looking at Calnago previous C60 build I would have to yield on the side of what he says that excess paint is built up in the hole. Try a small file inside of the hole and see if paint comes off. I wouldn't think it would hurt anything as the bolt holds the brake to the fork. You just want to be able to get the caliper into the fork. I believe THM might also tell you the same, time will tell. God Speed.
There are no new unread posts for this topic. Attachment(s) NEW THM-CARBONES FIBULA BRAKESET
[ Go to page: 1 2 3 4 5 ]
minimini
62
7269
Fri Oct 06, 2017 6:20 am
mrgray View the latest post
There are no new unread posts for this topic. THM Fibula brakes-setup help required
retired
9
833
Tue Aug 22, 2017 11:59 pm
retired View the latest post
There are no new unread posts for this topic. BB advice
Tricky1
Sun Sep 17, 2017 3:34 am
Tricky1 View the latest post
There are no new unread posts for this topic. Advice for the wife
rsantos450
14
899
Wed Oct 11, 2017 12:53 pm
jever98 View the latest post
There are no new unread posts for this topic. pedals advice?
Musiker
Sat Sep 16, 2017 7:19 pm
Musiker View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], eric0287, Keeno, otoman and 38 guests
