It is currently Mon Dec 18, 2017 11:25 pm
PostPosted: Thu Jan 12, 2017 2:21 pm
Can't get this stuff anywhere.
Lots of PTFE tube available in 2mm iD but is hard and will rattle.
Any ideas?
Thanks.
PostPosted: Thu Jan 12, 2017 5:48 pm
Are you including Jagwire?
I assume you want fully lined cabling? Liner with a steel cable through it will always have a chance of rattling.
Depending on access you can add donuts / o-rings, cross the cables over etc to minimise it.
PostPosted: Thu Jan 12, 2017 8:21 pm
I have a similar issue. I have been able to get something presented as cable liner but the diameter is too large and it was soft curly junk that buckles when you are trying to thread it into the bike. The curly part is a problem when it comes to avoiding cables wrapping around each other inside the downtube. It's fine for the first cable you install but it's hard to make sure the second cable doesn't end up wrapped around the first.
Some bikes come with good, small diameter, rigid stuff that is often installed as guide for the FD cable out of the BB and up toward the FD. I want more of that stuff.
wheelsONfire wrote:
When we ride disc brakes the whole deal of braking is just like a leaving a fart. It happens and then it's over. Nothing planned and nothing to get nervous for.
PostPosted: Thu Jan 12, 2017 10:00 pm
there's expanded ptfe (aka eptfe) tubing which can be soft, not sure how easy it'll be to find in small quantities though
PostPosted: Thu Jan 12, 2017 11:23 pm
Aican supply "hard" tubing with their Bungurus cable sets to seal the system between cable stops on external routing. It might be available separately.
PostPosted: Fri Jan 13, 2017 1:12 am
viewtopic.php?f=3&t=140825
See linked topic above; prendrefeu is onto something but I couldn't decipher the link he gave. If someone can pls let us know
Less is more.
PostPosted: Fri Jan 13, 2017 3:29 am
I got this from teamssx on ebay. Worked a treat redoing the gear cables on my Volagi Liscio
http://www.ebay.com.au/itm/New-JAGWIRE-Speed-Lube-Liner-for-brake-cable-Ultra-slick-lubricant-2-pieces-/301822356050?hash=item464603aa52:g:tYYAAOSwFnFWABa0
Listed as from Jagwire, but no idea, as it was unmarked and not packed in a box.
PostPosted: Fri Jan 13, 2017 11:57 am
not sure if this is what you looking for ... i gotten mine here. Used it for the exposed area of the shifters cable for my previous bike ...
http://www.ebay.com/itm/221611794356?_t ... EBIDX%3AIT
PostPosted: Fri Jan 13, 2017 5:33 pm
That looks like the right stuff. Thanks.
PostPosted: Fri Jan 13, 2017 7:27 pm
@Mr.Gib be aware that's just "regular" liner. I mentioned that in my original response to Valbrona. I got the impression you were after something a bit less flexible. The Jagwire is similar to Nokon liner and pretty much the same as Alligator liner.
There are no new unread posts for this topic. Inners and outers for gear cables?
alastairb
9
985
Thu Feb 23, 2017 10:35 pm
bremerradkurier View the latest post
There are no new unread posts for this topic. Internal cabling an FM-O66. Use liners??
Svetty
Thu Jul 27, 2017 1:25 pm
Marin View the latest post
There are no new unread posts for this topic. 3K bars with internal cabling
beanbiken
Fri Jun 30, 2017 6:52 am
beanbiken View the latest post
There are no new unread posts for this topic. Stems with internal cable routing
murphyk
Fri Oct 13, 2017 4:14 pm
kode54 View the latest post
There are no new unread posts for this topic. Caad12 internal disc cabling
lirek15
Fri Feb 03, 2017 5:20 am
tomee View the latest post
Users browsing this forum: avich, bfno, Bing [Bot], cunn1n9, faucon, ghostryder, Quattroporte and 45 guests
