It is currently Mon Jan 22, 2018 1:30 pm
Post new topic  Reply to topic  [ 106 posts ]  Go to page Previous 13 4 5 6 7 8 Next
PostPosted: Mon Feb 06, 2017 10:57 pm
Juanmoretime wrote:
Wow! Those look interesting.
When I looked for TI spindles for dura ace before, they didn't exist.
I am a little skeptical, because on the DA design the bearing race is actually on the spindle, which is a good reason to use hardened steel. But if the TI wear for a significantly length of time at all it might be worth trying.
PostPosted: Mon Feb 06, 2017 11:23 pm
Online
I have ti spindles in my 6700c pedals. They were 6700 spindles from "ti-spindles" in the US, which we took some material off to match the shape of the slimmer 6700c spindle. Weight is 216g, so I imagine DA with ti would come in at 210g.
Supersix Evo Hi-Mod - 4.51kg
PostPosted: Tue Feb 07, 2017 12:00 am
Kind of begs the question; why didn't Shimano use Ti in the first place? Plenty of others do.
Longevity? Avoiding having to put a weight limit on? Price? (I reckon for a 50$ premium, there'd be plenty of takers).
5 star and bespoke cycle tours in Majorca
Cycling related videos and reviews
PostPosted: Tue Feb 07, 2017 12:23 am
Because the bearing system uses the axle as the surface the balls roll on, rather than just being what the inner race of a cartridge beating sits on, therefore the material used plays more of a part in the performance
My Youtube Channel; Technical Bike Stuff, LOLz and Neo-Noir visions from the mirror realm
PostPosted: Tue Feb 07, 2017 12:43 am
therefore Titanium axle with piece of steel insert only at contact point which work as inner race of bearings would make it better, right?
PostPosted: Tue Feb 07, 2017 2:37 am
I'm going to put my two cents in to Look Keo Blade carbon. I rode time before.
the looks give me a better range of cleat adjustment options. the TI spindle version is light enough for me and I like the feel of the tension and the float.
20% cyclist/80% J.I.T
PostPosted: Tue Feb 07, 2017 4:48 am
Certainly. This would be a rather complex titanium-steel arrangement however, due to the nature of the Dura Ace bearing arrangement, requiring 3 steel sleeves, to handle the 3 bearings contact points (one of which is a long needle bearing) so it might not end up saving much weight. On the 9100 the needle bearing is gone however, so it could work out better on these new ones.
PostPosted: Thu Feb 23, 2017 7:46 am
Ok, i switched few rides ago on Look Keo2 Max Carbon pedals (i bought them last season, just to test Look system). Also wanted to test which tension is good for me and since i ride two clicks In from the lowest settings, i guess this is comparable to Look Keo 2 Carbon 12Nm (good i tried, as first i think that 16Nm will be the right one).
But please someone confirm me this. If i ride Look Keo2 Max Carbon two clicks in from the lowest setting, i need 12Nm or 16Nm Look Keo 2 Carbon?
And i can see 2017 version of Keo 2 Max Carbon Ti, beeing cheaper then just Keo 2 Max Carbon Ti. Is there any difference at all between 2017 version and older version ?
Now let me compare Look Keo2 Max Carbon to my Time:
- Clip In
Its definetly easier on Time Xpresso, but maybe im not used of this Look (since i ride them only for last 300 km).
The problem i have with Look is that they are always on wrong side, so i need to look down to find where to clip in. I guess i'll get used of it after more riding.
- Clip Out
On Time it's to easy for me, and i have often cliped out when i dont want. On Look its better. There is a moment when u know u are clipping out
- Whole feeling
Seem that i prefer Look vs Time. On Time when i push hard, i hate that lateral movement, and also sometimes i feel like this take some of my energy in that movement. On Look its stiff feeling, and i can feel whole my energy is going where should be going.
On Time it's easier to setup clits to dont have knee pain, on Look first ride i had some pain, but i adjusted very easy and now everything fine (im using 4.5 degrees gray cleats).
- Creaking
On Time no Any Creaking, on Look first ride i had some, but on last ride (134 km), no creaking at all.
- Walking
I have fer meters i need to walk until i start riding (like 10-15 meters). Better waling on the look cleats, and also seem that Look Cleats will last much more (on Time this is the weakest point. I was buying new cleats every 1500 km, max i rode was 3000 km but in reality i should replace them much earlier).
I'll give few more rides, but until now seem that i really like how Look Keo system works. If this continue in few more rides, ill switch to Keo Blade 2 Carbon Ti, since they are very light. Just hope that they'll have the same feeling as Keo Max 2 Carbon im riding now.
Another thing why i wanted to test Look setup, is because of powermeters based on their cleats. Very interested in BePro Pedal based Power Meter
PostPosted: Thu Feb 23, 2017 11:32 am
Administrator
The place I ordered my Dura Ace pedals where out of stock so I wound up with the Look Keo Max Blade carbon ti. 183 grams for the pair and no issues in about 200 KM of riding. Still have Xpresso's on the tt bike but may change if the Blades are still to my liking in a few more months. I really wanted to try the Dura Ace but the weight of the Looks made the decision change by me okay.
RESIDENT GRUMPY OLD MAN.
PostPosted: Thu Feb 23, 2017 2:35 pm
The DA pedals are butter smooth compared to what I've experienced with Look KEO blade pedals.
S-WORKS VENGE 1ST GEN
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
PostPosted: Fri Feb 24, 2017 9:54 pm
Time still makes the old RXS pedals. And that is not without reason! It is still their best pedal but they "had to" come up with something new. I went from shimando's ultegra, DA to Time rxs because: they are very light, the cleats last forever, no horizontal play (or how do you call this?) because of wear and they are very reasonably priced.
I had to get used to the immense float but now it feels very nice. No worries for knee injuries and not so critical alignment.
Newer isn't always better....
Oh, it's all right. I'm sure that we can handle this situation maturely, just like the responsible adults that we are. Isn't that right, Mr... Poopy Pants?
PostPosted: Fri Feb 24, 2017 10:25 pm
Exactly, and the Young's modulus of Titanium alloy is quite low, making it less than an ideal bearing surface.
PostPosted: Sat Feb 25, 2017 11:36 am
I use Look Keo 2 Blade..
After using 2 weeks, it started creaking..
Anyone solved this problem?
Legend HT 9.5 RED 22
Colnago C60 Super Record
S-Works Tarmac 2016 eTap
S-Works Tarmac 2015 DA
Cervelo R3 2015 UT
Cervelo S2 2014 UT
Spesh Venge Elite 105
PostPosted: Sat Feb 25, 2017 2:47 pm
Yep... bought Time rxs.
PostPosted: Sat Feb 25, 2017 4:22 pm
Use normal cleats and not the 'grip' version.
Sent from my HTC 10 using Tapatalk
There are no new unread posts for this topic. Look pedal removal - allen key vs pedal wrench?
mvcap
19
1670
Thu Nov 30, 2017 5:32 pm
Rick View the latest post
There are no new unread posts for this topic. Thread together BB for BBRight
morganb
Wed Sep 27, 2017 6:09 pm
stevod View the latest post
There are no new unread posts for this topic. Pedal stack
hlvd
Sat Jul 22, 2017 12:03 pm
hlvd View the latest post
There are no new unread posts for this topic. Ultra Torque L/H thread
beanbiken
16
991
Tue Jul 25, 2017 3:24 pm
AJS914 View the latest post
There are no new unread posts for this topic. Campagnolo missing thread
ncornelisse
Sat Sep 30, 2017 4:16 pm
Valbrona View the latest post
Users browsing this forum: Bing [Bot], Klaster1, morganb, Titusrider, Zakalwe and 40 guests
