Cannondale Evo Disc
by Hls2k6
Has anyone spent meaningful time on an Evo Disc? If so, could you share your experience with the stiffness of the rear QR? I'm a big guy (6'5" 180#) who generates a good amount of torque (400w threshold). LBS says the QR would likely rub and annoy me to no end. I know Cannondale started with QRs on the SuperX, but ultimately added a rear thru axle this year. I can't help but wonder if they'll similarly update the Evo. Thanks for any experiences anyone can offer.
by DonW
I've always imagined all disc road bikes will turn to TA eventually. I would wait.
by djwalker
I have the the 2017 Evo disk and have about 1200 miles on it. I also weigh about 185 and am pretty strong. I have NEVER had any rear disk rub. I also have a disk gravel bike with a rear qr that has almost 7000 miles on it and I have never had any rub with that either. The disk Evo is the best bike I have ever had- the great handling and ride of the regular Evo with the great braking of disks. I think that the worry of rub is overblown . The through axle mainly makes it a little easier to align the wheel. If you get it firmly into the dropout there isn't a problem.
by Broady
Apples and oranges but on my steel disc QR frame I've never had any disc rub, I'm a similar sized guy too. Make sure you use good skewers, Dura Ace do the job for me.
by Lieblingsleguan
I can't comment on possible rubbing but as the UCI has suggested 12mm TA front and rear as the standard so that race organizers can provide neutral support, I suppose Cannondale ist going to change that rear axle pretty soon.
by ryanw
Dunno if it helps, but I'm a 93kg (was 103kg on this bike) ex powerlifter and can put out well over 1,200w when sprinting.
NEVER had any flex or disc rub on my CAAD12...
'16 Cervelo S5 - 6900g
'17 Focus Mares Force 1
'15 Scott Addict Team - 6850g Sold
'17 Cervelo R3D DA - 7580g - Sold
'16 Cannondale CAAD12 DA Disc - 7560g - RIP
by CBJ
I would same the same too. I run a GT Grade carbon with QR rear and dics. As long as the rotor is nicely centered all is good. A carbon bike is one stiff structure. I got the bike with a DT Swiss 240 hubs so I can always upgrade to TA if my next frame has that.
by stockae92
I have a 29er Carbon MTB with QR rear, one of QR (Mavic maybe? I forgot) won't have rotor rub, but another QR (WTB) will have rotor rub from time to time and I have to stop, re-position and re-tighten.
So QR itself will play a part.
I don't race, so UCI has nothing on me. :p
And both system should be supported for a long long time.
