Shimano Brake Cable in Campagnolo Ultra-Shift Housing?
Valbrona
by Valbrona
Or in other words, is the diameter of Shimano brake cable the same as Campag brake cable?
(I know the nipples are different - the Shimano cable is to be used with Shimano levers).
Thanks.
kode54
by kode54
jag wire has Shimano one side...Campy the other. also PTFE coated. i usually get that as spares. if i have to replace the cables in my Campy or my Shimano....i can use same cable...i just flip it and trim off the one i don't need.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
ooo
by ooo
yes, it's the same diameter ø 1.6 mm
Valbrona
by Valbrona
Thganks. I knew Campag was 1.6, but have never been sure of what Shimano was.
