Hollowgram SL Spacer order.
nvroadie
by nvroadie
I have a Cannondale Hollowgram SL crankset and have the 104mm spindle. Does anyone know the spacer order for this spindle in a SuperSix Evo?
nvroadie
topflightpro
by topflightpro
One of the manuals listed here should tell you: http://www.cannondale.com/en/USA/Suppor ... ccessories
grover
by grover
The 104mm spindle should have a lip on the non-drive side.
Therefore no spacers on the non-drive side.
On the drive side you'll need a wavy washer and up to 5 (start with 3) of the 0.5mm shims to get correct compression of the wavy washer.
http://cf-prd.cannondale.com/~/media/Fi ... 03T175618Z
NOTE: The 104mm spindle will only work if your bottom bracket shell width is 68mm. You didn't specify which year SuperSix EVO you had. Some of them aren't compatible with the 104mm spindle. You may need to buy the 109mm spindle which doesn't have a lip and uses spacers. The user manual for setup with that spindle is the following one.
http://cf-prd.cannondale.com/~/media/Fi ... 03T181633Z
nvroadie
by nvroadie
I have a 2015 Evo, will the 104mm spindle work with that?.
dudemanppl
by dudemanppl
Yes. ;) On that note, I'll probably ship it out tomorrow.
nvroadie
by nvroadie
dudemanppl wrote:Yes. ;) On that note, I'll probably ship it out tomorrow.
Haha thanks
