Bad form to ask retailer to cut steerer tube down when ordering online?
Past 4 bikes bought online for myself and the missus I never thought to do this, but this time I'm considering asking the warehouse guys if they'd do it while setting up the bike. Is it considered bad form? Was thinking to ask them to cut it down and just leave 2cm there.
What you think? Bad form, they're busy enough?
Depends on the operation I guess, wouldn't hurt to ask. Though I would probably want to be 100% that the bike is coming with the stem you're going to use, and the height is correct for your fit.
It's not a hard thing to do. I would do it myself simply for the peace of mind of knowing it was done exactly as I wanted it.
I'd ask, if they can't I'd be fine with it though.
It doesn't hurt to ask, the bike will be checked before dispatch so wouldn't be a huge job.
If the bikes full price or less than 10% off I expect they'd do it.
Depends what you mean by online. A box shifting operation with no proper workshop on site, no chance, less risky to take it to a proper LBS. Or just buy your own tools. A shop that does mail order. I'd ask, and expect to pay a nominal sum.
Thanks guys, decided in the end to leave it. I did the other bikes myself and worked out fine. Just usually I ride around all goofy for a couple of weeks until I'm sure of where I want it, so thought them whacking a bit off would have spared me the goofiness
Shrike wrote:Thanks guys, decided in the end to leave it. I did the other bikes myself and worked out fine. Just usually I ride around all goofy for a couple of weeks until I'm sure of where I want it, so thought them whacking a bit off would have spared me the goofiness
The part in bold seems kind of important. How would you accomplish that if you were to get the steerer "whacked off" beforehand?
kkibbler wrote:Shrike wrote:Thanks guys, decided in the end to leave it. I did the other bikes myself and worked out fine. Just usually I ride around all goofy for a couple of weeks until I'm sure of where I want it, so thought them whacking a bit off would have spared me the goofiness
All my bikes are slammed, but leaving 2 cm would be nice and safe just in case. I've ridden the bike, can't see me leaving more than 5mm on there.
Or did you think I just picked a random number
I think your request to have the shop cut it down so there is only 2-3-4 cm extra steerer above the stem is fine. Asking the shop to do this before delivery should be expected. They may send all bikes with 300mm steerers as standard. Having them cut it to 250mm steerer should be fine. For free. Then with just a few centimeters extra steerer on the bike, refine the fit to your liking with spacers and/or stem changes.
Of course having the tools to cut it yourself is not bad either. Its an easy job and maybe less risk of anything going wrong if you do it all yourself. Why trust other people when you do not have to?
