It is currently Wed Jan 24, 2018 11:01 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Sun Jan 01, 2017 7:45 pm
This discussion originally started here:
need grippy material suggestion
https://r.tapatalk.com/shareLink?url=ht ... are_type=t
I decided to start a new topic so as not to derail the OP's thread.
It started off with Prendrefeu's suggestion to use TechFlex heatshrink fabric material as grippy material for handlebar tops. The material intrigued me because it is one contiguous tube of fabric that can be shrunk down onto the handlebar. I seem to have a talent for unwinding conventional spiral wound bar tape no matter how well wrapped the bar is. A contiguous tube of fabric should be impossible to unwind, theoretically. Thus, the experiment starts:
I wanted to have the length of TechFlex run as one continuous piece all the way from above the brifters down to the end of the handlebar. To do this, the clamp screw and cable housings would have to poke through holes in the TechFlex.
In order to do this, some way of marking the TechFlex with hole locations was needed. This was achieved with a template and red liquid electrical tape.
The clamp was inserted into the TechFlex first.
And then slid onto the handlebar. Spray adhesive was applied on the handlebar so the TechFlex, once shrunk, would not rotate around the handlebar. The end result is this.
I have not ridden it yet. I hope it lasts a long time. Having to go through all this work to replace the wrap on the bar is not something I want to do too frequently.
Last edited by WannabeWeenie on Sun Jan 01, 2017 7:45 pm, edited 3 times in total.
PostPosted: Sun Jan 01, 2017 9:56 pm
Very interesting. No wrinkles at the bends? And how much does it weigh :D
PostPosted: Mon Jan 02, 2017 12:57 am
On my bars, there isn't that much tape on there. The weight saving has been minimal.
Original LizardSkins bar tape:
TechFlex:
Last edited by WannabeWeenie on Mon Jan 02, 2017 12:57 am, edited 1 time in total.
PostPosted: Mon Jan 02, 2017 1:08 am
Cool experiment -- hope it stays on.
I can't see myself doing this for any other reason than it not unwinding, or if the grip/feel is really worth that much trouble!
PostPosted: Mon Jan 02, 2017 3:58 pm
Yeah. The only reason I did this was because of the unwinding.
PostPosted: Mon Jan 02, 2017 4:16 pm
Interesting, keep us posted.
PostPosted: Thu Jan 12, 2017 2:36 am
Observations after 10 rides on the trainer:
1. FlexTech provides better grip for hands that are wet with sweat than my old LizardSkins bar tape.
2. FlexTech is pretty thin and does not build up a bar as much as regular bar tape. This may be problematic for people with large hands.
3. There are no signs of wear but I would not expect to see any after only ten rides on a stationary trainer.
There are no new unread posts for this topic. Oversize pulley cages an experiment
motorapido
Tue Jan 31, 2017 3:30 pm
motorapido View the latest post
There are no new unread posts for this topic. Attachment(s) The $75 265g integrated handlebar stem experiment
[ Go to page: 1 2 3 4 5 6 ]
glepore
77
15715
Thu Dec 28, 2017 6:13 pm
glepore View the latest post
There are no new unread posts for this topic. Attachment(s) Anyway to install bar tape without using electric tape?
Noctiluxx
19
1083
Tue Jan 16, 2018 10:17 am
jacobeh View the latest post
There are no new unread posts for this topic. Tape instead of hoods?
whydobearsxplod
13
1471
Fri Sep 29, 2017 4:46 pm
whydobearsxplod View the latest post
There are no new unread posts for this topic. Attachment(s) Rim tape check
possibleweenie
7
655
Thu Aug 24, 2017 11:56 am
Marin View the latest post
Users browsing this forum: benzebub, fezi, Google Adsense [Bot], Mockenrue, Monkeyfudger, Pijpie, reedplayer, vinuneuro and 19 guests
