It is currently Wed Oct 18, 2017 9:02 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Fri Dec 30, 2016 8:25 am
Hi all
I currently have a sram red exogram 10 speed 53/39 130mm bcd crankset and would like to go to force 1x11. Can I just put a x sync 11speed 52 tooth 130 mm bcd chainring onto my sram red crank would it fit and work ok? Anyone done it?
PostPosted: Fri Dec 30, 2016 8:30 am
It's gonna sit a little outboard of centered so better chainline in the higher gears and worse chainline in the lower than a 1x spider & ring or direct mount ring would be. This could be okay or could be too much and cause excess wear in the largest two cogs. Depends on your bike.
PostPosted: Fri Dec 30, 2016 11:00 am
So the x sync chainring will fit, but might cause excess wear on the two largest cogs on the cassette . This should not be a major problem as I live in Suffolk and it is quiet flat around here so I hardly use the lowest gears. Many thanks for you help
PostPosted: Fri Dec 30, 2016 7:06 pm
Not a problem at all!
The tooth of the cx1 chain ring are offset to the inside for a correct chainline.
Though most aftermarket chainrings like wolftooth don't have this offset.
PostPosted: Fri Dec 30, 2016 7:36 pm
I thought I remembered reading this so I went on a search for confirmation and couldn't find it. Thanks for confirming.
There are no new unread posts for this topic. SRAM Force left crank arm weight ?
Xico
Thu Feb 09, 2017 2:10 pm
darnellrm View the latest post
There are no new unread posts for this topic. Sram red 22 exogram
Jowwy
Sat Apr 22, 2017 2:55 pm
Jowwy View the latest post
There are no new unread posts for this topic. Attachment(s) spider for k-force light crank arms other than power2max?
lovemyway
Fri Feb 10, 2017 7:56 pm
lovemyway View the latest post
There are no new unread posts for this topic. Help with Sram Red/Force RD
Hardstyle
Mon Jul 10, 2017 12:04 am
Hardstyle View the latest post
There are no new unread posts for this topic. SRAM Force 22 vs Red 22 shifters
loudtiger
10
627
Mon Aug 14, 2017 4:07 pm
youngs_modulus View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot], petromyzon, Yahoo [Bot] and 29 guests
