It is currently Tue Oct 17, 2017 6:37 pm
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Wed Dec 28, 2016 3:15 am
Has anyone here encountered an issue with the rear brake cable routing on the CAAD12 disc. I am running mechanical discs with compression less housing and can't get the housing to bend into the bb groove it's intended for (the housing is too stiff for the tight bend the routing requires).
Cheers
Time Skylon
PostPosted: Wed Dec 28, 2016 2:37 pm
If it comes to it, you will just have to go with regular outer.
Been there done that with alloy Synapse which routes rear brake cable through hole in head tube. Bonkers.
PostPosted: Fri Feb 03, 2017 5:20 am
Cheers
I run hydro and had similar problems with mine only because i was running a kogal BB to convert to shimano cranks and the line was hitting on the sleeve.
in the end i araldite the hose to the frame to keep it out of the way and hold it down.
i got rid of the plastic bit that routes the cabling
There are no new unread posts for this topic. 3K bars with internal cabling
beanbiken
Fri Jun 30, 2017 6:52 am
beanbiken View the latest post
There are no new unread posts for this topic. Internal cabling an FM-O66. Use liners??
Svetty
Thu Jul 27, 2017 1:25 pm
Marin View the latest post
There are no new unread posts for this topic. CAAD12 Disc Fram + New Campy Disc = Compatible?
NewYorkNick
19
2061
Sat May 13, 2017 8:17 pm
NewYorkNick View the latest post
There are no new unread posts for this topic. Caad12 disc with shimano crankset adaptor
martinfrias
Sat Oct 07, 2017 10:14 am
snowdevlin View the latest post
There are no new unread posts for this topic. CAAD12 Disc - tyre size and guards
22
1472
Tue Aug 22, 2017 9:06 pm
Bigger Gear View the latest post
Users browsing this forum: Baidu [Spider], Google [Bot], Google Adsense [Bot], lovemyway, tommasini, Yahoo [Bot] and 30 guests
