It is currently Sun Dec 17, 2017 3:18 pm
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Sun Dec 25, 2016 9:40 pm
Hello Weight Weenies,
I am building a sub 6kg CAAD10, and am going to use Ciamillo 0G-05 brakes, and was wondering if they are wide enough for use with Zipp rims (25mm wide). I also have some 21mm wide wheels, and am wondering how hard it is to switch between wheels.
nvroadie
PostPosted: Sun Dec 25, 2016 11:39 pm
I do not think that the ciamillo brake calipers will open wide enough to give you the clearance you require.However you have two options, 1) purchase new shallow fitting brake pad holders.(these were produced by Ciamillo so that the brakes could be used with the modern trend of wider rims. These are not cheap. 2nd. option is to take a 1mm or 2mm off the brake pads, to give you the required clearance.I did it this way when fitting Ciamillo brakes to Enve 3.4 rims. After one season i still have plenty of life left in the pads.
PostPosted: Mon Dec 26, 2016 2:22 am
I think that filing down the pads or modifying some pad holders sounds like a good idea.
PostPosted: Mon Dec 26, 2016 1:11 pm
My OGs work fine with the normal pad holders, and I didn't even need the low profile ones.
With the low profile holders the Ciamillos should work with up to 26mm rims IIRC.
PostPosted: Mon Dec 26, 2016 3:38 pm
Thanks for the feedback
PostPosted: Mon Dec 26, 2016 5:58 pm
The latest Micros were engineered to also be able to easily switch between the wide rims and say a narrow pair of ksyriums that you might use for training. The GSL's and Micros have the best stopping power btw. The older 05's are a little softer
PostPosted: Mon Dec 26, 2016 6:12 pm
How are the 0G-Ti calipers?
PostPosted: Mon Dec 26, 2016 6:39 pm
The older 05's are about 10-12 years old. Ted has improved the design and continues to refine it every year. I agree the GSL's and Micro's are the strongest. The design really started improving with the introduction of the Zero G which came after the OG Ti series. With carbon braking surfaces you need all the power you can get. I love the GSL's and Micros. I have several sets and have been using their stuff since they first came out.
PostPosted: Mon Dec 26, 2016 6:58 pm
I think I need to do this properly and get some GSLs. Thanks to all for the advice!
There are no new unread posts for this topic. Ciamillo GSL Micro clearance with 25mm tubular
TheBlackPath
Sat Nov 11, 2017 11:49 am
TheBlackPath View the latest post
There are no new unread posts for this topic. Ciamillo rear brake servicing - removing excess play
Slimtim
7
1008
Wed Dec 21, 2016 4:08 pm
Slimtim View the latest post
There are no new unread posts for this topic. Space for a Wahoo mount with Zipp SL Sprint + Zipp SL 70 Aero setup?
Shrike
Fri Nov 17, 2017 10:08 am
Shrike View the latest post
There are no new unread posts for this topic. Zipp SL-88 vs. Zipp SLC2 TB
TSJ
Thu Sep 21, 2017 8:55 pm
TSJ View the latest post
There are no new unread posts for this topic. Zipp 454 NSW reviews
[ Go to page: 1 2 3 4 ]
pesto13
52
7918
Tue Mar 21, 2017 8:13 am
cyclespeed View the latest post
Users browsing this forum: Google [Bot], joe1234, nickf, topflightpro and 36 guests
