It is currently Sat Oct 21, 2017 1:27 pm
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Fri Dec 23, 2016 7:55 pm
I couldn't believe air does add weight to the bike, so tested it out myself, and :shock: Bike with both real 25mm tyres at around 90psi vs complete flat tyres made a whopping difference of 20gr! Not that you could win something in real usage, but it's a trick if you are just a few gr above 6kg and really want a scale pic at sub 6kg f.ex :mrgreen:
Canyon Ultimate CF SLX 2013
Scott Addict Orica Greenedge
Canyon Endurace CF SLX
PostPosted: Fri Dec 23, 2016 9:00 pm
pump with Helium ;)
Mark Twain
PostPosted: Fri Dec 23, 2016 9:35 pm
The "weight" of air is highly variable.
PostPosted: Sat Dec 24, 2016 3:06 am
I put new tyres on the other day and did the same out of curiosity, air added 10gr.
PostPosted: Sat Dec 24, 2016 3:11 am
Low tyre pressures = WW trick! :P
PostPosted: Sat Dec 24, 2016 2:56 pm
Also to note is if you are at altitude and pump your tyres up to the same pressure as at sea level. The bike will "weigh" more at sea level than at altitude.
Hambini
The science behind Aero Road wheels!!
Ceramic v Steel Bearings: The Truth
Visit the Hambini Website
PostPosted: Sat Dec 24, 2016 9:09 pm
This is true WW :D
PostPosted: Sun Dec 25, 2016 5:06 pm
So if you aren't too fat, you can run lower psi, more weight savings
PostPosted: Thu Dec 29, 2016 6:01 pm
It isn't so much a change in weight as it is a change in density... You are adding more air molecules into the relatively same volume of space.
Sent from my HTC 2PST2 using Tapatalk
PostPosted: Fri Dec 30, 2016 7:26 am
That is a good technical correction and reminder of the physics at work.
PostPosted: Sat Jan 07, 2017 4:36 pm
No, it's tautologous gibberish. By definition a change in density for the same volume is a change in weight, assuming constant gravity.
PostPosted: Sat Jan 07, 2017 5:21 pm
I think the word you are looking for is "mass", not weight ;) Density is a ratio of mass:volume... Weight is a measurement of gravitational attraction. But what does my tautologous gibberish know? (That's not even a tautology is, FYI)
PostPosted: Sun Jan 08, 2017 2:10 pm
Apparently your tautological gibberish doesn't know that we all live on the surface of the earth, therefore when you increase the mass of a bike you increase the weight by exactly the same degree, always. The word 'weight' is equally as valid as the word mass. If there's anything worse than being that pedantic it's being that pedantic and wrong :roll:
This applies equally to your original point. Air has weight. Adding more air to tyres adds more weight. This statement is no less valid because the density of the air in the tyres has also increased. It's not a situation where one or the other is true. They are both equally true at the same time.
PostPosted: Fri Jan 20, 2017 3:29 pm
I wonder why I said "assuming constant gravity" in my original post? And it is a tautology, because you are saying the same thing twice. Adding more molecules into the relatively same volume of space [sic] is indeed a change in density which is precisely as much a change in weight. They are (for a constant volume in constant gravity) exactly the same thing. (Even more amusingly, and tautologically, our common measures of mass are also measures of weight at Earth-normal gravity.)
[/pedant mode]
There are no new unread posts for this topic. Bontrager R4 Tubular tyres - views?
campagowlo
Mon Apr 17, 2017 7:41 pm
russianbear View the latest post
There are no new unread posts for this topic. 28C tyres on Dura Ace 9000 Brake Calipers
chutneyyy
Thu Jun 29, 2017 7:58 am
Delorre View the latest post
There are no new unread posts for this topic. Fast, light 700x20c tyres / tires?
kman
Mon Jan 02, 2017 11:44 am
kman View the latest post
There are no new unread posts for this topic. List of 320tpi Open Tubular-Style Clincher Tyres
Valbrona
7
1175
Tue Apr 04, 2017 1:35 am
ferrarista View the latest post
There are no new unread posts for this topic. bike weight
huffington
Sat Apr 29, 2017 12:54 pm
shineplus View the latest post
Users browsing this forum: aaric, Baidu [Spider], darnellrm and 29 guests
