FAILURE Shimano Cranksets
erwinpat
by erwinpat
Kindly comment if you or a friend experience this. Scary I might say...catastrophe waiting to happen.
Sent from my Redmi 4 using Tapatalk
1swiftvelo
by 1swiftvelo
Replaced one two weeks ago for a client for the same thing. It's not the first was ultergra
Rippin
by Rippin
Sh!t happens.
____o
_`\<,_
toiyuet
by toiyuet
wingguy
by wingguy
That's impressive! Though given the sheer number of 6800 chain sets out there the failure rate must be microscopic still,
Ref Taiwan, are you thinking that lightweight Aluminium chain sets have more of a weakness in countries that are very hot and very wet?
victorduraace
by victorduraace
Must be something in glue/bonding method susceptible to failure in wet and hot conditions
prendrefeu
by prendrefeu
But that's impossible! Shimano components are infallible and perfect!
That must be photoshop!
(sarcasm)
RussellS
by RussellS
The new crank arm on the right looks good. But the pedal looks like garbage. Does this rider drag the bike for hours every day with the pedal in gravel? How does a pedal get to look like that? Broken crank on left. Breaking the tip of the rank off is not good. But the whole crank arm looks like he dipped it in acid every day for a year and pounded on it with a hammer and roughed it up with a grinder. The chainring looks like it is sort of newish. But the crank arm? No wonder it broke. Despite the broken crank arm, this is a much better picture of bike part abuse and how to destroy bike parts. I would never blame Shimano for this.
prendrefeu
by prendrefeu
Now that's sarcasm!
mattr
by mattr
The crank arm on the right is the front half of the hollowtech forging. The left hand is the inside/back half of the forging.
You'd need the parts in front of you to work out the actual failure mode.
But, at a guess, I'd put this at shimanos door. Probably a slip up in the forging process .
mattr
by mattr
prendrefeu wrote:^^^^^^
Now that's sarcasm!
nah. Just not looking at the picture carefully enough.
Calnago
by Calnago
It's just cosmetic.
5 8 5
by 5 8 5
RussellS wrote:The new crank arm on the right looks good. But the pedal looks like garbage. Does this rider drag the bike for hours every day with the pedal in gravel? How does a pedal get to look like that? Broken crank on left. Breaking the tip of the rank off is not good. But the whole crank arm looks like he dipped it in acid every day for a year and pounded on it with a hammer and roughed it up with a grinder. The chainring looks like it is sort of newish. But the crank arm? No wonder it broke. Despite the broken crank arm, this is a much better picture of bike part abuse and how to destroy bike parts. I would never blame Shimano for this.
You say some very strange things..............
dynaserve
by dynaserve
Calnago wrote:It's just cosmetic.
Bit more than cosmetic, but luckily the failure mode is ideal to simply Loctite it back in place.
jeffy
by jeffy
do you even watts bro?
