It is currently Wed Jan 24, 2018 12:56 pm
Post new topic  Reply to topic  [ 25 posts ]  Go to page 1 2 Next
PostPosted: Tue Dec 20, 2016 6:05 am
I'm owner of a Cannondale Supersix EVO ( previous model ) equipped originally with a SRAM RED 22 groupset.
I've bought a SRAM Etap mini group and made the swap of both derailleurs and brake levers .
My concern is the following :
when reatching the 11th sproket with the Etap rear derailleur , without chain , I observe a mechanical clash between the cage ( low pulley area ) and the spokes of the wheel .
I noticed that the rear derailleur is moving not parallel to the bike axis when going from right to left ( upwards ). It's like he's turning around a virtual pivot , a bit like the "Yaw" front derailleur .
Rem : With a mechanical RED 22 derailleur , when chain is removed, there is approx a gap of +/- 3-4 mm between derailleur cage and spoke in the 11th position .
I've made the following tests , without success :
- replaced the Cannondale hanger by an other Cannondale hanger , comming from an other Supersix EVO .
- tested different rear wheels
- tested the Etap rear derailleur on an other Cannondale Supersix Evo frame .
Result is always similar : clash with the spokes .
I do not understand what's the origin of this problem .
PostPosted: Tue Dec 20, 2016 6:08 am
You need to align hanger with a hanger alignment tool such as the park tools DAG. New hangers and bikes do not come pre aligned. They almost always need alignment.
Sent from my SM-G900W8 using Tapatalk
My RCA
PostPosted: Tue Dec 20, 2016 6:09 am
Limits set correctly?
Using Tapatalk
PostPosted: Tue Dec 20, 2016 8:05 am
Rem : With a mechanical RED 22 derailleur , when chain is removed, there is approx a gap of +/- 3-4 mm between derailleur cage and spoke in the 11th position.
This is normal , I have the same issue. With the rear derailleur under tension there is no problem. If you push the low pully forward you see that it will line perfectly with the sprockets. And I cannot imagine there are a lot of people riding without a chain. :smartass:
Scott Foil Team edition / Holdsworth Competition / Gluing tubular and add water.
PostPosted: Tue Dec 20, 2016 8:57 am
^^^this
on my bike even a mechanical red (10-speed) just touches, with 11-speed i think it's more pronounced - the hanger is perfectly aligned
broken chains aren't common, i do wonder about the consequences if it should happen with the rd on the biggest cog, but presumably i'll be going slow in that situation!
PostPosted: Tue Dec 20, 2016 10:37 am
I'm running ETap + TCR ISP '16 + Reynolds carbon clinchers. Clearance is really tight!
PostPosted: Tue Dec 20, 2016 11:56 am
It needs the chain it's in the tech docs but with out the tension of the chain ( SRAM mechs don't use a sprung pivot like campag and shimano ) the mech will go into the spokeS.. Put the dam chain on already :smartass:
Skunkworks Bikes
PostPosted: Tue Dec 20, 2016 3:03 pm
Yup, my eTap RD without chain will touch my 404 Firecrest spokes, just a tiny lil' bit. Enough to destroy the spokes if the wheels flexed. But then again, i dont think I will ride my bike wihtout a chain... :mrgreen:
PostPosted: Fri Dec 23, 2016 3:57 am
I second the idea of checking the hanger alignment. That vintage SuperSix has a really flexible hanger. I was constantly tweaking mine in normal use ( no crashes or falling over). I would worry about what might happen if my chain broke with that interference.
PostPosted: Fri Dec 23, 2016 4:15 pm
djwalker wrote:
That vintage SuperSix has a really flexible hanger. I was constantly tweaking mine in normal use ( no crashes or falling over). .
This is why the pro-team had stainless steel hangers made for these bikes.
PostPosted: Sat Dec 24, 2016 5:29 am
I have a super six himod, and yes, I always keep a spare hanger on the side. They seem to go out of alignment (no, it is without a crash...)
Going back to the original issue, what would happen if the chain brakes or drops. They shouldn't happen but what if?
PostPosted: Sun Jan 01, 2017 11:07 pm
Location: Physically in Montréal, but my mind is in the Pyrénées
I noticed this too when I built my Evo eTap, even with correctly set limits. I wasn't sure if it was normal or not so I checked the derailleur hanger alignement, mine was a bit off but not critically so. I aligned the hanger and that still happened but as everyone says, once the chain is installed, it's okay. I checked the distance between each pivot of the rear derailleur's parallelogram, it's actually not a perfect parallelogram so it seems like they designed the cage to pivot a little bit to 'aim' at the chainrings throughout the cassette range, not unlike the Yaw front derailleur.
I guess if a chain snaps or drops and you are on the biggest rear cog, it could create a mess, although the direction the spokes would go when riding, maybe each spoke would just ramp and rub the cage and push it as the cage angle makes it so the lower pulley end is what contacts the spokes, without chain tension, it would be pointed toward the rear and the now front pointing top of the cage wouldn't hook the spokes... Not ideal but, maybe not ripping everything off. But it wont touch the spokes when you are shifted on smaller cogs.
Dan Gerous
PostPosted: Mon Jan 02, 2017 5:01 am
Yeah, the original Evo hanger was soft as hell.
They updated it, adding some strengthening dimensions to it and perhaps using harder material. I had my first Evo go out of alignment with a bent hanger, with no crashing too, and just through constant shifting putting force on the it.
I suppose there is a cut off point for how hard a hanger can be, or it wont do its job when it comes to the crunch, but Cannondale went a bit too soft on this one for sure.
My Youtube Channel; Technical Bike Stuff, LOLz and Neo-Noir visions from the mirror realm
PostPosted: Mon Jan 02, 2017 6:34 am
It's not an Evo issue, it's the eTap rd. I've had it on two different bikes, neither an Evo and both touched the spokes without the chain. It's a moot point since the chain is necessary to function...
Strava
Current Stable. The Snob Machine | The Crumpton
The Ex's. LS Siena: 6.21kg | Parlee Z5 SLi: 5.9kg | LS Xicon: 5.76kg | C59: 5.7kg | Cervelo R5ca: 5.09kg | Fuji Altamira SE - 6.2kg | Scott Foil - 6.2kg | Evo - 5.18kg | LS Classic - 6.7kg
PostPosted: Fri May 26, 2017 5:08 pm
Just to cross-pollinate overlapping threads, a similar discussion is happening over here: viewtopic.php?f=3&t=143893&p=1319259#p1319259
The long and the short of it:
• Dropped and broken chains happen. This is absolutely without question a problem that should have been designed for. You will not have 'more serious problems' than a dereaileur running into the spokes of your wheel while you are moving. This situation will CAUSE 'more serious problems'
• Whether you have the problem or not really depends on the exact make, model and year of all of your parts involved. Some combinations are easier to solve for than others. The case of 10sp mavic wheels appears to have a resolution. Others hopefully will follow.
There are no new unread posts for this topic. Help with eTap rear derailleur hitting the spokes (on Canyon CF SLX)
dorin
44
5538
Thu Jan 18, 2018 12:15 pm
dorin View the latest post
There are no new unread posts for this topic. SRAM etap red
suedaf
Sun Mar 12, 2017 9:48 am
wingguy View the latest post
There are no new unread posts for this topic. Sram etap Red
Post Man Pat
Wed Mar 15, 2017 1:01 pm
keiro View the latest post
There are no new unread posts for this topic. Sram Etap
Jowwy
Fri Aug 25, 2017 1:32 pm
Jowwy View the latest post
There are no new unread posts for this topic. Sram Etap will there ever be an app.
Allen254
Mon Dec 18, 2017 12:26 pm
jlok View the latest post
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Jian81, Roentgun, siim, TurboKoo and 19 guests
