It is currently Sun Dec 17, 2017 6:52 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Sat Dec 17, 2016 1:27 pm
Hello all! I have a quick question.
I currently have a Quarq Riken coupled to GXP 172.5mm arms. I'm curious if I am able to take the Riken spider from my GXP arms and swap it over to SRAM S series BB30/PF30 arms. Has anyone tried this before?
PostPosted: Sat Dec 17, 2016 2:38 pm
I am fairly confident that yes, you can swap the spider between GXP and BB30 arms. You should probably double check with Quarq though.
PostPosted: Sat Dec 17, 2016 2:52 pm
How about the calibration?
Thst would be my main concern.
PostPosted: Sat Dec 17, 2016 3:00 pm
Pretty sure its the same from what I looked at on mine, swapping is easy just make sure you clean off the old lock tight between the crank and spider and reapply. I think it takes 24hrs to cure the lock tight before riding if I remember right.
PostPosted: Sat Dec 17, 2016 3:05 pm
I have done this a few times. Works fine. Go for it. Just make sure that when you re-install on new S900 crankset that you torque Quarq mounting screws to proper spec. and that you use Quarq specified loctite product on the spider / crank interfaces.
If it's the newer quarq its not a problem I've done it a couple times never any problems or changes, I think calibration was a issue on the older ones like the s975
PostPosted: Sun Dec 18, 2016 11:20 am
Thank you all for the quick responses! Just saved me a load of $$!!!
There are no new unread posts for this topic. switching from pf30 24mm to pf30 bb30 cranks ??
Allen254
Tue Nov 21, 2017 8:02 am
mrlobber View the latest post
There are no new unread posts for this topic. Quarq DZero Spider Sram Rotor compatibility
Jian81
Sun Dec 17, 2017 7:02 am
dre_lo82 View the latest post
There are no new unread posts for this topic. help installing sram red 22 crank (PF30 with bb30 spindle)
Allen254
Mon Dec 04, 2017 11:33 pm
Kurets View the latest post
There are no new unread posts for this topic. Lightest 30mm crank (bb30 = ok) with removable spider
alcatraz
34
2100
Tue Sep 26, 2017 3:04 pm
madcow View the latest post
There are no new unread posts for this topic. Sram Red BB30 chainset (integral spider) fitted to BBRight....
pavlo
Wed May 17, 2017 12:47 am
pavlo View the latest post
Users browsing this forum: CarlosFerreiro, crn, cyclenutnz, Google Adsense [Bot], Matthijs1973 and 47 guests
