Will a RD6800SS fit a 30T cassette?
zalle
by zalle
I have a 12-30 cassette, will the RD6800SS fit? The RD6700 has 30T written on it, but I believe the 6800 does not.
I know shimano say that SS is for 28T and GS is for 32T... But I want to know the truth! :P
benzebub
by benzebub
it depends on your rear derailleur hanger.. if it is long enough it will work.
My chorus derailleur has a 29t limit but I've got it to work with a 32t shimano cassette so nothing is written in stone..
But I could be wrong
Kurets
by Kurets
Exactly, it might work, it might not. I have heard of people making the RD-6500-SS work with 30T+ cassettes and that one is only specced for 27t max. There is no way to figure out without trying unless you can find someone with the same frame that has tried it before you.
zalle
by zalle
So I should buy one which I can return...?
zalle
by zalle
Well, so I put the RD6800SS on my 10 speed 12-30 cassette and it fits perfectly!
Jhomewood
by Jhomewood
"it will work" vs "it will work well" are two very different things. i went long cage this year and i'll never go back, running in the big-big is much smoother now (not that i do it often)
Hexsense
by Hexsense
For 11-28 or 30 which likely work on both mid cage and short cage you should decide from your hanger's length.
If it is short then you are safer buying a mid cage one.
Otherwise...
mid cage vs short cage version of the same derailleur can also different in B-knuckle length and other parts not just the cage.
On my bike, my RD hanger are pretty long and Mid cage RD has longer (go lower) B-knuckle (to clear room for bigger cassette) so i have to back off B-tension screw all the way out to make upper pulley stay relatively close to cassette. And that make my upper pulley go very far forward ahead of the cog and cable entrance are from bad angle (like almost 30 degree down rather than horizontal and or higher than horizontal.
I think i should change to short cage which will give me better cable angle for my long RD hanger bike since it has shorter B-knuckle which then doesn't need me to back off B-tension screw this far.
picture of my bike's rd, I know it's Sram not Shimano but still apply for long cage vs short cage in general.
spdntrxi
by spdntrxi
yes depends on hanger/frame.. as an example I can use a 30T with my 9150 SS but 32T won't work on my Parlee Z5SLi. My wifes' 2014' Madone6 can fit the 32T with the same 9150 SS RD.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
Briscoelab
by Briscoelab
Yes
