THM crankset on a C60
Hi,
Do you guys know wich spec a thm crankset including BB is needed to fit a colnago C60?
Thank you
Thank you
- wheelsONfire
You can read about it here.
http://www.bicycling.com/bikes-and-gear ... olnago-c60
For the ease of things, i think it's a good idea to contact THM directly over email and ask them.
Bikes:
Open *UP* (2016.04.14)
wheelsONfire wrote:You can read about it here.
Thank you for your help greatly appreciated
for what it is worth i had trouble. i had a m3 thm crank i think (srm) and my mechanic couldn't get the crank in-board enough. now the stated q-factor for both as i recall is 143.5 mm. mind you it might have been a dodgy mechanic. thm certainly seemed to think it should work.
Bobo S&S Steel Bike - 7.5 kg
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
For the C60 you need the Thm bb86 bb, which Thm sometimes calls Shimano Press fit. That along with the standard Colnago threadfit cups and you're all set. We've done them on a few C60's with no problems.
Thank you guys . Seem pretty straight forward as per your instruction. Now I need to source one cheaper or used.
yeah, its a nice crankset that will fit a colnago c60 with their PF Shimano cups... but if you're looking to source a used one, I'd stick with one of their newer cranks.. The original gen 1 clav's need a spacer to keep the inside of the spider from rubbing the housing cups.
THE PAST: 2005 C'dale R700, 2006 Spesh S-Works Tarmac Gerolsteiner, 2009 Pinarello Dogma FPX My Way, 2011 Time RXR VIP
THE PRESENT: 2016 Colnago C60 ST01, 2017 Wilier Cento 10 Ramato, Cinelli Gazetta
THE FUTURE:
THE FUTURE:
jimaizumi wrote:yeah, its a nice crankset that will fit a colnago c60 with their PF Shimano cups... but if you're looking to source a used one, I'd stick with one of their newer cranks.. The original gen 1 clav's need a spacer to keep the inside of the spider from rubbing the housing cups.
That's good to know as I don't like putting spacers or make any modifications in the bottom/crank area. It always lead and or just not work as smoothly.
