It is currently Thu Jan 18, 2018 11:13 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page 1 2 Next
PostPosted: Tue Nov 29, 2016 3:36 pm
Alright I'm THAT guy. Search as I may, I can't seem to find what I was looking for. I know we have talked about this before, but I recall some website online where you could compare two different geometries \ fit to match a new bike to an old bike. I can't recall if it was a pay for service or what but I'm in a bit of a pinch with time and was looking to order and setup a new bike to match an old bike.
I have the old excel spreadsheet comparator but it's a bit excessive in detail for me to process.
Thanks guys.
Just ride ..
http://1k2go.bigcartel.com
https://www.instagram.com/itsacarr
https://www.strava.com/athletes/1044522
PostPosted: Tue Nov 29, 2016 4:22 pm
http://www.bikegeo.net/
http://bb2stem.blogspot.nl/
Most "innovations" in cycling are solutions for non-existing problems.
PostPosted: Tue Nov 29, 2016 4:35 pm
You have to know every measurement to compare. Sometimes they aren't published on the manufacturer's web site so you have to look elsewhere.
I used the bb2stem one and it did take me a few minutes to understand how it worked. I thought it was easier to work with it in Excel on a downloaded version.
Colnago C59
PostPosted: Tue Nov 29, 2016 5:07 pm
Don't rely on stack or reach only. Some frame builders include the dust cap (headset cover) in their number while others don't.
The nice thing about BB2stem is that you can check the stack/reach given by the manufacturer.
PostPosted: Tue Nov 29, 2016 6:34 pm
Thanks so much guys for the references :)
Just ride ..
PostPosted: Tue Nov 29, 2016 9:14 pm
frame comparison tool on www.velogicfit.com is free, you just need to sign up
However, there will be some downtime today as we switch out the backend server.
As far as things like headsets being included in numbers - we run test formulae over all the data we import to find any obvious errors (there are a lot, including from big brands that make a big deal about bike fit) and fix or make enquiries where there is an issue. Can't be sure that we catch everything but we're certainly making an effort to ensure data quality. If we know the headset is included in the numbers it gets removed.
http://www.speedtheory.co.nz
http://www.velogicfit.com - 3D Motion Capture and Frame Finder Software
PostPosted: Fri Dec 02, 2016 8:44 pm
cyclenutnz wrote:
frame comparison tool on http://www.velogicfit.com is free, you just need to sign up
Great tool! Just a question : are there updates forseen for the newer bikes, just like the 'new' Canyon Endurace cf slx or the 2016 Ultimate cf slx? The new BMC roadmachine is there, but not the canyons f.ex.
Current bikes:
Scott Addict Premium Disc 2018
Scott Addict Orica Greenedge 2015
Retired:
Canyon Endurace CF SLX 2016
Canyon Ultimate CF SLX 2013
PostPosted: Fri Dec 02, 2016 10:00 pm
http://gearinches.com/blog/misc/bike-ge ... comparator
Good old spreedsheet :)
PostPosted: Sun Dec 04, 2016 10:15 pm
The problem with those bikes is that they're only available with proprietary bars/stem. And their stems don't really work with the standard calculation. You'll note that the BMC RM01 isn't listed, nor Madone 9, Venge Vias etc. Same on the Tri/TT side - no superbikes.
I have created a position calc tool for the road bikes with specific bars and will be adding that to the Advanced Bike Finder (the paid for tool) at some point. The Frame Comparison tool was just intended as a way for our site to offer value to everyone, not just the fitters who pay for our commercial tools, so draws on the full database of standard bikes but won't get the special calcs.
As far as updating goes in general - at 190 brands currently so it takes a while to work through all the new stuff. Prioritised according to my own favouritism or at request.
PostPosted: Sun Dec 04, 2016 10:21 pm
Thx for the feedback, makes sense! And :thumbup: for the effort you put in it!
Current bikes:
Retired:
PostPosted: Mon Dec 05, 2016 11:57 am
I did a comparing of my current bike and my dreambike Colnago C60
Diverge is 52 with 110 -17 stem and Colnago is 48S with 110 -8 stem.
As I understand not all numbers are at the colnago website and I just took the same as the Diverge.
The numbers seem pretty close but how about the ones that colnago don´t publish?
Can someone help me to see if Colnago C60 is as close as possible to my current bike. As far as I can see it is but I´m not an expert at this!
Thanks
PostPosted: Mon Dec 05, 2016 9:23 pm
Your spacer height isn't measured properly. Measure from the top of the frame to the bottom of the stem - then we can do the comparison properly
PostPosted: Mon Dec 05, 2016 11:39 pm
I'm not sure about Colango's published numbers but you may want to figure out if Colnago's tallish conical headset top cap is included in your measurements. With my C59, I was able to search and find the missing measurements.
I saw a post the other day with reference to these guys:
https://www.velogicfit.com/pricing/
You can try their free tool. They probably have the C59 in their database.
Colnago C59
PostPosted: Tue Dec 06, 2016 1:40 am
Probably have the C59... Of course we have the C59 - the database grew from me collecting info about bikes I liked.
List of Colnagos in our system (velogicfit):
A1r
A1r CX
A1r Donna
Ace
AC-R
AC-R Disc
Arte 2.0
C50
C59
C60
C60 Disc
CLD
CLX 2.0
CLX 3.0
CLX 4.0
Concept
C-RS
CX Zero Alu
CX Zero Evo
CX Zero Evo Disc
CX-1
EPS
K-Zero
M10
Master X-Light 06
MC27
Prestige
Prima
Strada SL
V1-r
V1-r Disc
The older ones have calculated Reach and Stack.
Also, the C60 data is a bit messy on the public site right now. Will be sorted in the next hour when a cleaned up database gets pushed live.
PostPosted: Tue Dec 06, 2016 8:18 am
Not sure how u mean?
On my Diverge I have "slam that stem" dust cap. So I put in 2 mm as that messurment.
On the C60 as I understand there are two dust caps wth the frame. One conical and one lower - I plan on using the lower.
There are no new unread posts for this topic. Online Frame Comparison Tool??
EvilEuro
16
1034
Thu Jul 20, 2017 11:58 pm
silvalis View the latest post
There are no new unread posts for this topic. Comparing 2015 Bianchi Sempre Pro and Cervelo R3 framesets
BiaNeutron
Sun Feb 05, 2017 5:43 pm
BiaNeutron View the latest post
There are no new unread posts for this topic. Comparing weights: new generation shimano cranks vs previous
alcatraz
Fri Jan 12, 2018 9:24 pm
Marin View the latest post
There are no new unread posts for this topic. Colnago warranty service?
wilwil
12
1419
Sun Jun 25, 2017 5:48 pm
wilwil View the latest post
There are no new unread posts for this topic. Bianchi and other brands customer service
Boshk
22
1652
Tue Oct 17, 2017 3:38 pm
MXGimp View the latest post
Users browsing this forum: Bing [Bot], corky, crbeardy, tomycs and 43 guests
