It is currently Sun Dec 17, 2017 1:52 am
Post new topic  Reply to topic  [ 134 posts ]  Go to page Previous 14 5 6 7 8 9 Next
PostPosted: Sun Mar 12, 2017 11:27 am
Hi. Just net here and ordered EW-WU111. Quick question: thuis unit is for internal frame mounting. Which place suits best to place it for best reception? And is it just plug and play?
Thanks
PostPosted: Sun Mar 12, 2017 11:55 am
I put mine in the frame and plugged into the internal battery. Is working fine and was plug and play
PostPosted: Sun Mar 12, 2017 2:36 pm
@Macses
I think officially Shimano says to mount them outside the frame for best reception, but I put my WU101 inside where the cable from my A junction enters the frame (just behind the head tube), and I'm having no issues at all.
Mileage may vary if you have an aluminum frame with internal cable routing, but I've seen enough people that have them working inside with carbon to safely say it works fine.
PostPosted: Sun Mar 12, 2017 6:35 pm
I have a carbon frame. I have ultegra di2 but ordered the wu111. I read it also works with ultegra but was designed for duraace. But since it's smaller and advertised as in frame solution and same privé as the wu101 I opted for this.
PostPosted: Sun Mar 12, 2017 7:38 pm
havana wrote:
I'm using a custom 12-30 (11sp) cassette; which is not configurable. So i chose 11-30 in stead.
No matter how I configure the system, the system shifts to 50x28 (=10th cog) before the system shifts to the small ring... impossible to adjust the threshold point to the 2nd largest cog. In other words the chain line is still horrible. Disappointing to say the least !
I agree that having a limit on Synchro Shift that it will only drop from the big ring to the little one when you reach either the second biggest cog (say 28T) or the biggest one (say 32T) is disappointing to say the least! Also, quite hard to understand the reason for it. I would say avoiding the largest two cogs would be quite a sensible idea. Perhaps they believe that the strain on the chain or gears would be too great, for some reason, although the semi-synchro would do exactly what I want if I hit the front change while in the third cog (25T)!
I thought it might be a bug in the e-tube GUI, so having tried every type of cassette and every combination of chain rings, I thought I would just try and hack the preset settings file. However, when I did this, loading the hacked preset gave a validation error on the Rear Derailleur Change Point, so it seems to be more than just a bug.
Looking at the settings file, the ChangePointRD for the Synchromap2 Direction Down has acceptable values of only 1 to 2 (or 254 which appears to be for semi-synch mode). When I set it to 3 it gave the validation error on loading into e-tube.
;Direction UP:0 DOWN:1
Synchromap2_1_Direction=0
;ChangePointFD 1 to 2
Synchromap2_1_ChangePointFD=1
;ChangePointRD 1 to 11 , 254
Synchromap2_1_ChangePointRD=8
;AimPoint 1 to 11
Synchromap2_1_AimPoint=6
Synchromap2_2_Direction=1
Synchromap2_2_ChangePointFD=2
;ChangePointRD 1 to 2 , 254
Synchromap2_2_ChangePointRD=2
;AimPoint 1 to 11
Synchromap2_2_AimPoint=4
So it appears to be a deliberate choice by Shimano!
I hope they change their mind(s).
Geoff
PostPosted: Thu Mar 23, 2017 2:24 am
Have people got a buzzer to work?
Where/what is the Buzzer??
* Bluetooth D Fly?
* Garmin Head Unit?
* Something else to plug into Junction Box??
PostPosted: Thu Mar 23, 2017 4:13 am
Probably a translation issue. The edge 1000 can be set to beep prior to a synchro front ring change.
PostPosted: Thu Mar 23, 2017 8:04 am
Noise comes from Garmin. I have 520 and it notifies when I'm on either end of gears.
PostPosted: Thu Mar 23, 2017 10:59 pm
Do you have to do anything to set this up apart from connect your D Fly to Head Unit?
Looking through the Firmware Updates, does only the Bluetooth D Fly's EW-WU101 / EW-WU111 and not the ANT+ Only SM-EWW01 send the Buzzing Request through to the Head Unit?
PostPosted: Fri Mar 24, 2017 8:42 am
You need to update the firmware on the Garmin
Wheelworks.co.nz
New Zealand handbuilt wheels
PostPosted: Fri Mar 24, 2017 11:21 am
Is it possible to see the gear mode (m, s1 or s2) on a Garmin 810? I can see the gears and such but not the mode of synchro shifting
Thanks!
PostPosted: Fri Mar 24, 2017 12:07 pm
Thanks!
I have a 810 as well and I haven't seen it. It might be in the Di2 "About" page. As I recall, that's where you can change the cassette and chainring sizes, so I'm going to assume that's where it'd be. That being said, probably just easier to reach below the stem and hit the button depending on how you have the junction box mounted.
PostPosted: Fri Mar 24, 2017 12:22 pm
They've added an extra field to the edge 1000 called shift mode. You can display it just like any other field on data pages. So check in "gears" category for that field.
Sent from my SM-G900W8 using Tapatalk
My RCA
PostPosted: Fri Mar 24, 2017 12:26 pm
Are you able to change the shift mode on your edge 1000? I tap it where it says "Tap to change" then it says updating but doesn't change the shift mode.
PostPosted: Fri Mar 24, 2017 12:32 pm
I had that happen last week when I first updated everything. But this week it seems to be working just fine. Go figure.....
My RCA
There are no new unread posts for this topic. New Shimano eTube 3.2.1 enables synchro shifting for 9070?
2old4this
Thu Mar 30, 2017 8:21 am
TurboKoo View the latest post
There are no new unread posts for this topic. Setting up AX3000s with Tune housing
4ibanez
Fri May 12, 2017 5:23 am
shimmeD View the latest post
There are no new unread posts for this topic. Setting up the Shimano Di2 EW-RS910 Bar End Junction A Charging Point 2 Port
melchionda
13
4480
Sun Apr 02, 2017 2:03 am
sugarkane View the latest post
There are no new unread posts for this topic. XG-1190 shifting
beanbiken
9
352
Thu Dec 14, 2017 9:48 am
2old4this View the latest post
There are no new unread posts for this topic. SRAM shifting with Di2
sturvey
Sat Mar 11, 2017 6:28 am
Racingevo View the latest post
Users browsing this forum: AZR3, Baidu [Spider], DJT21, Exabot [Bot], mogwaiboi and 41 guests
