Setting up Di2 Synchro shifting?
Neider
by Neider
How do I change shift mode? I'm a Di2 newbie. I'm using the iPad E-TUBE app. I got the latest firmware and I think I got synchro shift loaded on the bike. I saw the post about double tapping the EW90 to change shift mode, but I need more details. I'm also able to connect my Edge 520. It has a setting for "Shifting Mode" and has a "M Tap to Change" under it. When I select the function it goes to "Updating..." for a while and returns to the original display. It does not give me an option to change shift mode.
Neider
by Neider
TurboKoo
by TurboKoo
Sounds like you didn't have new battery.
Scott Foil
Shimano 9150
Shimano FCR-9100-P
Shimano C60 tubulars
gmarsden
by gmarsden
Rapid double clicking changes the mode in my 9070 group but the Garmin 820 screen doesn't seem to do anything when you tap it as prompted in the sensor setup screen.
Neider
by Neider
I've got the new battery. I have changed my shifter configuration. I'm guessing the 520 problem is likely a Garmin issue. The 520 does not have a touch screen. Can you be specific about rapid button on the junction box. What are the LEDs doing?
Neider
by Neider
I tried the button clicking again. I just wasn't clicking fast enough. It's working great. I may have to get out and ride tomorrow in crappy weather. Thanks!
BdaGhisallo
by BdaGhisallo
I have just come back from my first ride with syncro shift and consider me not interested. I tried semi-syncro for about 20 miles and then put it back into full manual mode. I feel much more in control of my gearing that way.
muppetkeeper
by muppetkeeper
Aaaaggghhhh, my local bike shop GLUED my battery into my seat post when they built my bike last year. So I had to choose between breaking the battery or the seatpost!!
If you are interested, inside your battery are two slightly shorter than AA lithium cells and a circuit board about 3cm by 2cm all bound together with ribbon electrodes. :-)
Johnny Rad
by Johnny Rad
muppetkeeper wrote:Aaaaggghhhh, my local bike shop GLUED my battery into my seat post when they built my bike last year. So I had to choose between breaking the battery or the seatpost!!
Sorry to hear about the rotten luck. As we all know from firsthand experience (good and bad), a great bike shop is worth their weight in gold (or just do it yourself).
gbrown
by gbrown
I've just setup the new BT-DN110 battery on my Trek Domane Di2 and checked out the Synchro Shift.
I have Dura Ace FD-9070 front Derailleur (and Dura Ace 50/34 Crank) but Ultegra 6870-GS rear derailleur and shifters, with an 11-32 cassette. I already had the EWW01 Wireless unit and didn't need to upgrade that, just the battery.
Really easy to upgrade and everything seems to work OK, just two little glitches so far, both of which I see others reporting here.
Tapping on my Garmin 1000 to change the shift mode shows updating, then leaves the mode unchanged, as others have reported, so I guess this is a problem with the firmware (I have the latest at both ends), either Garmin or Shimano, as the communication is breaking down between the two. Double clicking the button on the EW90-A junction box works fine, and the Garmin beeps and shows the new shift mode.
Finally, I have tried to customize the shift pattern for Full Synchro Shift, and it is all possible apart from I can't move the auto shift from the big ring to the little ring from the 28T cog to anything else apart from the 32T, I wanted to move it to the 25T, but for some reason all the other cogs are greyed out! I have tried moving the target cog up and down, but it makes no difference at all, only 28T or 32T can be selected. I see others report much the same thing, so either Shimano think there is a reason to stay in the big ring until 28T or they have a bug.
I've moved the switch from the little ring to the big ring down one cog to 14T, switching to 18T, as this is actually a smaller gap and means the change in front ring is delayed and possibly avoided. Reducing the number of front changes seems to make sense, as does making the ratio's slightly closer.
I wanted to change the shift to the little ring for the same reason, and to avoid having the chain quite as crossed (50T/28T) so hopefully Shimano will fix whatever is making this not possible.
I have left the button switches mirroring a mechanical setup, so I don't have to learn a new habit and can switch between bikes, but will only have to change the right hand up and down in full synchro shift. I still have the option of a manual change of the front ring, with the left hand. If I find I'm doing this a lot, I will give Semi Synchro a try, as shifting the rear 2 to match is something I currently do manually.
Well done Shimano for retro-fitting this to the older kit. They did get a new battery sale out of me, but I guess my battery would have needed replacing eventually!
Geoff
muppetkeeper
by muppetkeeper
I would have expected better from them. I would have gone to have it out with them, but they upgraded my bike to Di2 in exchange for some consulting I did for them, so thought it better to keep the relationship an ruin it for the £50 or so I hoped to get for the old battery. Still frustrating though.
Johnny Rad
by Johnny Rad
muppetkeeper wrote:...so thought it better to keep the relationship an ruin it for the £50 or so I hoped to get for the old battery. Still frustrating though.
The high road is best. Difficult to take, but usually the best route. Good for you!
I'm surprisingly (ha!) far from perfect and know that it's easier said than done.
muppetkeeper
by muppetkeeper
It helps that I cut my hand open getting the battery bits out, and I didn't want to get blood on my handlebar tape cycling down to shout at them.... :lol:
cyclespeed
by cyclespeed
That's bizarre!
Not only are there all kinds of cheap battery mounts that work well at keeping the battery in the seatpost, but if they really wanted to use something 'sticky', why not silicone, instead of glue? That would have held it, but it could still just be pulled out....
muppetkeeper
by muppetkeeper
That's bizarre!
My new battery is held in with bubble wrap. I wrapped long cableties around the back end to help me pull it out if needed.
