It is currently Wed Jan 17, 2018 6:44 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Sun Nov 27, 2016 6:29 pm
Ever since I switched to tubulars, I've had the famous problem of the push-on pump head blowing off the valve at higher pressure (~110 psi).
It's never been an issue for me before, but now I'm wondering if I can switch the Topeak pump head to a more traditional screw-on one. Something like the Birzman Snap-it Apogee or Lezyne ABS2 chuck looks promising. Has anyone done this successfully?
This is the pump head I'm currently using: https://www.topeak.com/global/en/produc ... -smarthead
PostPosted: Sun Nov 27, 2016 9:44 pm
I put a KNC pump head on my Topeak, it's excellent, really locks on well.
PostPosted: Sun Nov 27, 2016 9:55 pm
i don't see why it wouldn't work.
here's a review of some pump head if it helps: http://www.tririg.com/articles.php?id=2 ... d_Shootout
PostPosted: Sun Nov 27, 2016 11:18 pm
Thanks for pointing out KCNC - will look more into that.
It may not work because of different hose attachments. The Birzman and Lezyne ones have very different looking attachments. Birzman looks closer to what my Topeak pump has, but not sure if the diameters are the same.
PostPosted: Mon Nov 28, 2016 5:01 pm
I've got the Topeka screw on head and don't recommend it - it usually unscrews the valve core when removing. All screw on chucks have a tendency to do this. Before you go there, try to find a new gasket for your current head, yours is probably worn and will work correctly once replaced.
PostPosted: Fri Apr 14, 2017 8:46 pm
KCNC pump head is the best $45 I spent in a while. I was starting to hate latex tubulars due to pumping inconvenience until this purchase.
56cm PR00 Colnago Extreme Power
PostPosted: Sat Apr 15, 2017 4:49 pm
Yep I'll second that KCNC pump head
There are no new unread posts for this topic. Canyon H31 mount screw
Kristian78
Sun Sep 10, 2017 7:59 am
MayhemSWE View the latest post
There are no new unread posts for this topic. Where can I find a deda adjustment screw
dwn2sk8
Mon Apr 03, 2017 1:26 am
dwn2sk8 View the latest post
There are no new unread posts for this topic. Ultegra 6800 Reach Lever Screw broken
probertsqbe
Tue Feb 14, 2017 12:09 pm
probertsqbe View the latest post
There are no new unread posts for this topic. Picked up a screw... fork scratched - nail polish, or paint?
mike001100
Sun Dec 17, 2017 7:54 pm
antonioiglesius View the latest post
There are no new unread posts for this topic. Front derailleur limit screw rounded off (SRAM eTap), need plier recommendation
Shrike
Wed May 03, 2017 7:40 am
Shrike View the latest post
Users browsing this forum: Google Adsense [Bot] and 37 guests
cron
