It is currently Thu Dec 14, 2017 10:29 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
 Post subject: Campagnolo wheels??
PostPosted: Thu Nov 24, 2016 4:45 pm
Good, day; Happy Thanksgiving to all; I want to do some wheel shopping maybe tomorrow. I run 28mm tires, my choices are Campagnolo Eurus or Shamal new C17 class.. I read and reread, the campy 2017 catalog and the Eurus wheels are height/width 24-27/20 The Shamels are 24-27/22 If a rider could bring me up to speed on this C17 Class I would be thankful. Best'
  • Campagnolo Shamal Ultra C17 2-WAY FIT wheelset Shimano
  • 976.9 EUR
  • Price includes 19% V.A.T. which will be deducted when goods are leaving the EU. Shipping costs may be added.
 Post subject: Re: Campagnolo wheels??
PostPosted: Thu Nov 24, 2016 5:07 pm
in brief: wider internal and external width. more volume requires less pressure = better ride. wider rim makes the sides of the tires less "light bulb" shaped, theoretically better aerodynamics. wider tire on the rim decreases rolling resistance = faster.
PostPosted: Thu Nov 24, 2016 5:27 pm
Thanks; it also looks like Campagnolo brought other wheels I.E. the Zonda series up to the wider C17 but not the Eurus, ?
PostPosted: Thu Nov 24, 2016 5:34 pm
Personally, I'd go with the Zondas. I don't think the Shamals are worth the premium.
PostPosted: Thu Nov 24, 2016 9:16 pm
I'd absolutely just get the Shamal Ultras (C17). A friend came back from the Death Ride in California and had used some 50mm profile wheels. First thing he said was "I want some low profile wheels!", and after looking around got the Shamal Ultra Clinchers (C17, but not the two-way fit). They are very nice wheels and if I was in need of a clincher set this is what I'd get. They were perfectly round and true in the truing stand, and the dish was perfect as well from the get go. I mounted 23's and 25's Conti 4000S tires on them and compared them to the same tires mounted on my Campy Neutron rim (c15). My friend ended up going with 23's on the new Ultras.
I was going to do a mini review of these wheels but never got around to it so I'll post some pics I took of the same 25mm tires on both the c17 rims (Shamal Ultra) and the older Neutron rims....
Continental 4000S clincher 25mm on Shamal Ultra (17mm internal width):
Same 25mm tire on older Neutron rim. I wouldn't even think about putting a 28mm on this rim. As it is, I have to not only release the brake release to remove them, but also turn the brake adjuster on the caliper themselves as well.
And when checking dish, trueness and roundness... these wheels were as close to perfect as it gets...
Interestingly, the drive side flange is oversized yet again, and measures 82mm, versus 76mm on the new Boras, and 70mm on the pre 2015 Boras...
And they measure 22.5mm at the brake track...
Mounting the clinchers was a breeze too... by hand. Compared to my Neutrons which is quite a task to say the least. Opted for the standard clincher version versus the two-way fit version since the standard tire/tube setup is reliable and works, no matter what.
Anyway, I don't think you could go wrong with these wheels, but a 28mm tire is going to be big, so make sure you have the clearance for it.
Good luck in your shopping...
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Thu Nov 24, 2016 10:12 pm
I have a Eurus wheelset and it has been faultless . I run 23mm tires and they aren't too buldgy but if I were buying to today, I'd go with a wider rim.
FWIW, Ribble had the Shamal wheelset as their black friday special.
http://www.ribblecycles.co.uk/catalogse ... /?q=shamal
I do have to agree with the above that the Zonda C 17 wheels look great @ under $400.
Colnago C59
PostPosted: Fri Nov 25, 2016 7:38 pm
Thanks to one and all The Shamal set C17 it is!
PostPosted: Fri Nov 25, 2016 8:43 pm
PowerMeister
just wondering about wider/width... would we a non pros notice the difference in being faster on a wider rim instead of the narrow version? would you also tell the diff between an aero and a non aero frame?
"Racing is life. Anything before or after is just waiting."
--Steve McQueen--
PostPosted: Fri Nov 25, 2016 10:48 pm
I doubt one could feel the speed but a wider rim yields better rolling resistance or allows you to run lower pressures. For example, you can run a 25mm tire on the C17 rims and it won't look lightbulb shaped. (See the pics posted above by Calnago.)
You get more air volume inside the tire with the wider rim. Compared to a narrow rim at the same pressure (say 100psi) you'll have lower rolling resistance. You may also be able to run 85psi and get the same rolling resistance on the wider rim that you had on the narrow rim at 100psi - that is where the comfort thing comes in.
Colnago C59
PostPosted: Mon Nov 28, 2016 1:31 am
I went through this recently, and decided on the Shamal C17's over both the Zonda's and the slightly cheaper C15 Shamal's.
Very happy with my decision, absolutely amazing wheelset. I run 23mm Conti GP4000S2's and they mate to the rim just about perfectly - I wouldn't run 25's on these wheels.
It's ALL about the bike.
PostPosted: Fri Jan 06, 2017 8:17 pm
Quick question.
I bought a pair of Zonda C17 with Campagnolo freehub from PBK.
Included in the box was QR and manuals.
Am I missing a spacer?
PostPosted: Fri Jan 06, 2017 8:19 pm
Don't think so. A spacer for what? You're using Campy cassettes I presume. Just put them directly onto the freehub, no spacers required.
Colnago C60 - PR99
PostPosted: Fri Jan 06, 2017 8:42 pm
True. There are no spacers with Campy.
PostPosted: Fri Jan 06, 2017 8:51 pm
Googled zonda c17
PostPosted: Fri Jan 06, 2017 9:28 pm
Might that pic above be from a set of Zondas with a Shimano freehub, and the spacer intended for use with a 10sp Shimano cassette if desired? I don't know, but for Campy... no spacer required.
Colnago C60 - PR99
  • 976.9 EUR
There are no new unread posts for this topic. Attachment(s) Campagnolo 11 speed using 34/50x11/36! Yes it can be done with PRE-2015 Athena LC Big Gears on Campagnolo 11 speed
colnagoaddict
12
993
Mon Aug 28, 2017 12:26 am
c50jim View the latest post
There are no new unread posts for this topic. Rear Derailleur Pulley Wheels / Jockey Wheels - 17t and oversized sizes - where?
prendrefeu
10
522
Tue Dec 05, 2017 7:39 am
addictR1 View the latest post
There are no new unread posts for this topic. Questions on Campagnolo EPS
mlok
12
1264
Fri Oct 20, 2017 9:15 pm
avispa View the latest post
There are no new unread posts for this topic. Attachment(s) New groupset Campagnolo?
[ Go to page: 19 10 11 12 13 ]
Daniel1975
191
20754
Thu May 18, 2017 1:36 pm
claus View the latest post
There are no new unread posts for this topic. Another Campagnolo Drama
Valbrona
14
1798
Tue Dec 27, 2016 5:20 pm
graeme_f_k View the latest post
Users browsing this forum: antonioiglesius, Dowks, dvq, Google [Bot], jj911c2, shonanmike and 41 guests
