It is currently Mon Dec 18, 2017 2:17 pm
Post new topic  Reply to topic  [ 366 posts ]  Go to page Previous 120 21 22 23 24 25 Next
 Post subject: Re: Ultegra update?
PostPosted: Mon Aug 28, 2017 2:23 am
ooo wrote:
FC-R8000 looks more solid and cleaner on inside
+1. On the old crank one can see the black excess glue that is used to glue the two halves together...
PostPosted: Mon Aug 28, 2017 2:26 am
dvdslw wrote:
pdlpsher1 wrote:
seaneT1 wrote:
Is the r8050 also available as well now? :D
I haven't found any online.
Starbike shows to have the short cage R8050 ready for dispatch. I emailed them and they confirmed it.
Good news. I'm in the U.S. so it might take just a bit longer to get here. I spoke to a large mail order shop in Boulder and they told me 'any day' now. I need the RD-8050 GS long cage derailleur. I already have the new 11-34 cassette and I need the Di2 derailleur to go along with it. I use the 11-34 for special use, one day climbing rides that have lots of steep climbs.
PostPosted: Mon Aug 28, 2017 2:55 am
Nice. I want to replace my R785 shifters. Deciding between the 8070 and the 9170 levers.
PostPosted: Mon Aug 28, 2017 4:51 am
Another U.S. based online retailer is showing availability on Sept. 19.
PostPosted: Thu Sep 07, 2017 5:40 pm
Hi there I do upgrade to my 6800 to 6870 di2, so I have shifters, front and rear derailleur.
So what else I need, cables, battery, charger????
PostPosted: Thu Sep 07, 2017 5:45 pm
junction box A (cables from left shifter to A, right shifter to A)
junction box B (cable from A to B, from battery to B, from B to front derailleur, from B to rear derailleur)
battery
battery mount (seatpost or somewhere in the frame)
battery charger
 Post subject: Ultegra update?
PostPosted: Thu Sep 07, 2017 6:43 pm
battery
battery charger
So I need box A and B both ?
For internal use
Box A
Box B
Battery
Wires
PostPosted: Fri Sep 08, 2017 7:03 pm
battery
battery charger
For internal use
Box A
Box B
Battery
Wires
You do, unless you want to skip B and run cables from the drifters to the bottom bracket
viewtopic.php?t=140189
PostPosted: Fri Sep 08, 2017 7:23 pm
Does anyone know how you determine the length of the wires you need when you upgrade to di2?
PostPosted: Fri Sep 08, 2017 7:30 pm
viewtopic.php?t=127833
A tends to be at the stem, B tends to be around the bottom bracket. Battery is often in the bottom of the seat post. You can take a soft tape measure and roughly figure out what the lengths should be. If internal, then round up a bit, since
PostPosted: Sat Sep 09, 2017 9:12 pm
Planning to upgrade st-rs685 shifters with the st-r8020 ones. Dealers manual showing need to use Funnel Adapter. But from the picture it doesn't look all that necessary. I want to make sure that it's really needed as I have trouble to buy it. Bike24 isn't selling it yet (getting the shifters from there).
Can anyone confirm it? Thanks.
PostPosted: Mon Sep 11, 2017 9:27 am
Anybody know of any carbon rear derailleur Cages available to cut down on weight a little?
Or any other part out there to cut down overall weight?
(Please don't reply "buy dura- ace" haha)
PostPosted: Mon Sep 11, 2017 10:42 am
The funnel adapter should be included with one of the shifters.
PostPosted: Mon Sep 11, 2017 12:53 pm
Hope you are right. That would be great. I was looking at some package informations to Dura ace shifters and it wasnt mentioned. I was actually planning to get the shifters first and then to get the adapter if its actually needed.
Thanks for the heads up!
PostPosted: Mon Sep 11, 2017 1:25 pm
Why not? That's the only answer that does make sense imho.
There are no new unread posts for this topic. Cervelo S5 due an update in 2018?
Shrike
Tue Apr 25, 2017 8:08 pm
Shrike View the latest post
There are no new unread posts for this topic. Attachment(s) PSA - B.O.R. German Sealant (UPDATE) - DO NOT BUY
possibleweenie
26
1912
Tue Nov 21, 2017 2:11 pm
eins4eins View the latest post
There are no new unread posts for this topic. MyCampy App crash after firmware update
tadrums
Sat Dec 24, 2016 2:07 am
tadrums View the latest post
There are no new unread posts for this topic. Bianchi Speciallisima 2017 update??
Conradsleight
Mon Jan 23, 2017 1:40 am
Conradsleight View the latest post
There are no new unread posts for this topic. Garmin 520 Firmware Update 12.1 and eTap
TarugoKing
10
965
Tue Aug 01, 2017 3:23 pm
wheelbuilder View the latest post
Users browsing this forum: CarlosFerreiro, fromtrektocolnago, Johnnysmooth, seaneT1, seve88 and 34 guests
