It is currently Sat Oct 21, 2017 10:00 am
Post new topic  Reply to topic  [ 345 posts ]  Go to page Previous 119 20 21 22 23 Next
 Post subject: Re: Ultegra update?
PostPosted: Wed Aug 16, 2017 10:16 am
Di2 firmware update released for R8050 series:
2017-08-16
FD-R8050 3.1.0
RD-R8050 3.0.3
ST-R8050 3.0.1
ST-R8060 3.0.1
ST-R8070 3.0.1
PostPosted: Wed Aug 16, 2017 10:54 am
With the firmware updates do they describe what each update fixes, adds, changes etc?
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Wed Aug 16, 2017 8:37 pm
Lol....it's shimano..."bug fixes"....is as good as it gets usually.
PostPosted: Fri Aug 18, 2017 4:42 pm
Online
what should I do if the trim doesn't work when I'm on the big chainring?
it's fine on the small one, but the FD cage barely moves on the big ring.
PostPosted: Fri Aug 18, 2017 5:17 pm
Cable tension is too tight, you need to make sure left shifter is clocked to zero when you do initial cable tension and not in the trim position.
Blog: http://glorycycles.blogspot.com/" onclick="window.open(this.href);return false;
Flickr: http://www.flickr.com/photos/glorycycles/" onclick="window.open(this.href);return false;
PostPosted: Fri Aug 18, 2017 5:56 pm
I thought the manual says to adjust cable tension in the trim position?
http://si.shimano.com/pdfs/dm/DM-RAFD001-03-ENG.pdf page 18
My Strava Profile
2016 Cannondale CAAD12
PostPosted: Mon Aug 21, 2017 1:28 pm
Yes it does, but that won't work very well if the left shifter is set to the trim position when the cable is initially installed.
PostPosted: Mon Aug 21, 2017 2:32 pm
Is the r8050 also available as well now? :D
PostPosted: Mon Aug 21, 2017 4:23 pm
I don't understand what you are saying? How will following the manuals instructions not work well? I have the fd-9100 on one bike and just installed the fd-r8000 last weekend, they have the same adjustment procedure.
My Strava Profile
PostPosted: Thu Aug 24, 2017 7:44 am
I haven't found any online. One online shop shows ETA middle of Sept.
PostPosted: Fri Aug 25, 2017 11:05 pm
FD-R8050 diagram uploaded:
File comment: FD-R8050
Again, it's copy-paste from FD-R9150:
File comment: FD-R9150
PostPosted: Sun Aug 27, 2017 7:18 pm
Online
Ultegra Di2 - GCN's first look
PostPosted: Sun Aug 27, 2017 9:40 pm
slake21 wrote:
I saw that this morning...Pretty good video with a lot of info.
Basically like the new group but the hefty size of the crank does make me wonder a bit
Could be an illusion but looks massive in that video...Does it really need to be that chunky?
PostPosted: Sun Aug 27, 2017 11:01 pm
Starbike shows to have the short cage R8050 ready for dispatch. I emailed them and they confirmed it.
PostPosted: Sun Aug 27, 2017 11:04 pm
FC-R8000 looks more solid and cleaner on inside
File comment: FC-R8000 vs FC-6800
File comment: FC-6800 inside
File comment: FC-R8000 inside
There are no new unread posts for this topic. Dogma F8 hydro disk brakes/ Di2 Ultegra vs Cannondale SuSix Di2/Ultegra
bikebike
Sat Oct 29, 2016 4:41 am
bikebike View the latest post
There are no new unread posts for this topic. Attachment(s) PSA - B.O.R. German Sealant (UPDATE) - DO NOT BUY
possibleweenie
23
1378
Thu Aug 17, 2017 10:12 pm
Calnago View the latest post
There are no new unread posts for this topic. Cervelo S5 due an update in 2018?
Shrike
Tue Apr 25, 2017 8:08 pm
Shrike View the latest post
There are no new unread posts for this topic. Garmin 520 Firmware Update 12.1 and eTap
TarugoKing
10
839
Tue Aug 01, 2017 3:23 pm
wheelbuilder View the latest post
There are no new unread posts for this topic. Bianchi Speciallisima 2017 update??
Conradsleight
Mon Jan 23, 2017 1:40 am
Conradsleight View the latest post
Users browsing this forum: hamd, ipaul, jeanjacques, kurisu, L3X, raisinberry777, TobinHatesYou and 35 guests
