It is currently Sun Dec 17, 2017 5:53 am
Post new topic  Reply to topic  [ 366 posts ]  Go to page Previous 118 19 20 21 2225 Next
 Post subject: Re: Ultegra update?
PostPosted: Wed Jul 26, 2017 7:40 am
rainerhq wrote:
rainerhq wrote:
Just ordered rear der from LBS for 75€ (68£). Should be here in 10 days.
My shortcage arrived and installed. Works great with 11-32 cassette. Front ring 48T.
197g
Guess it would be a stretch using 50 at front and gs would be required? Don't know the cage length do you of the ss version?
PostPosted: Wed Jul 26, 2017 10:41 am
CS-HG800 11-34 stock 2-7 day at 86,95€ (vs 11-32 at 72,95€/41,95€ R8000/5800)
https://www.bike-components.de/en/Shimano/CS-HG800-11-11-speed-Cassette-p58013/
pdlpsher1 wrote:
jeffy wrote:
looking at the various 2018 bikes being announced, it is very disappointing that (other than BMC) none of the 8000 & 9100 bikes have direct mount hangers - at least in the product photos. It is not as if a hanger is a huge overhead.
Figures. Someone has mentioned that Shimano has priced the direct mount version of the OEM rear derailleur to be cheaper than the regular version in order to speed up adoption. But I guess no one at the bike manufacturer has noticed it?
mfg uses same frame design to make da/ult/105 versions of bike,
most will wait at least until 105 rd before adpoting dm
some will skip it if they want sram option on frame
 Post subject: Ultegra update?
PostPosted: Wed Jul 26, 2017 2:58 pm
So, on the subject of this whole Direct Mount hanger business...
1. The new 9100 derailleur, and I presume the new Ultegra rear derailleur, both have removeable "b-links", correct? This b-link, which I used to refer to as the "extension thingy", is essentially there so that when attached to a regular hanger the derailleur is positioned in the same place it would be if it was attached to a Direct Mount hanger after removing the b-link. So why the fuss over wheteher there is a DM or a regular hanger?
2. If frame manufacturers only made DM hangers then that would mean SRAM and Campagnolo rear derailleurs could not be used with these frames, unless there was another hanger available to be swapped out. Not good. As it is now, the b-link is provided for current hangers. So what is the advantage of creating frames with a hanger that will not work with SRAM or Campagnolo rear derailleurs? Or more generally, what is the advantage, period?
3. Is it better? So far, the new 9100 rear derailleur has left me with quite mixed feelings. I suppose it's better if you want to run pie plate type cassettes, after all... the design is carried over from their mountain bike stuff. But it doesn't seem like they thought through some of the practical issues this design presents to a lot of road bikes. Specifically, I'm talking about rear wheel removal. With some road bikes, especially ones with fairly substantial Bottom Bracket mouldings, it is a royal pain in the ass to do a simple rear wheel removal. The derailleur just does not want to move out of the way enough to allow the wheel to slide out. With mountain bikes there's usually a ton of clearance up front of the tire between the bottom bracket. Also, BB drops aren't as large as on road bikes. So on mountain bikes this issue is moot. But with road bikes and quick release wheels, that wheel needs to both drop down and slide forward a substantial amount to clear the derailleur and in some cases all kinds of jamming up occurs due to the rear derailleur not being able to move easily out of the way. Add to this that some folks want to run larger tires and the problem gets worse.
4. I suppose through axles and longer chainstays to accommodate bigger tires would help all this, but where does the mountainization of the road bike stop, or does it? I like the fast elegant quick release and easy removal of the rear wheel. I think Shimano needs a few tweaks to their latest rear derailleur design before I'll start jumping up and down praising its virtues because so far this single aspect of it is proving to be a big negative. Rear wheel removal should be an easy operation on any frame, or at least no more difficult than it ever was. If it's not, then someone has messed up in their design process. Fix it Shimano. Please, fix it.
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Wed Jul 26, 2017 7:41 pm
AFAIK Rear wheel removal is significantly less of an
issue with DM Hangers and Thru-Axle wheels. The design of the QR endcaps
(and that they protrude passed the internal wall of the dropout creates the issue.
Perhaps I don't understand- but can't swappable hangers be created? Will he new BMX TM not be able to be used with SRAM??
PostPosted: Wed Jul 26, 2017 8:15 pm
Oh, you mean like mountain bikes have, which also have a ton of clearance between the tire and the bottom bracket, and the BB drop is not nearly as significant as it is on road bikes. Yes, no issue there. Moot point.
I'm talking about a direct mount hanger on current road bikes with quick release wheels. Under these circumstances the new derailleur makes rear wheel removal more difficult in a lot of cases. Through axles would probably help however, since the wheel could just drop straight down and out I suppose, provided the derailleur swings back enough to allow it. But I'd hate for the quick release wheel to go the way of the DoDo bird too. All for what?
Yes, different hangers could be created I suppose, but again, why? The new derailleurs have the b-link to hook up to existing hangers. Do we really need to make everything obsolete, for what, the sake of change for change's sake? It's getting ridiculous.
Colnago C60 - PR99
PostPosted: Wed Jul 26, 2017 9:45 pm
Easier wheel removal and weight savings. Depending on the bike the ease of wheel removal is far bigger deal. On my bike I can't remove the rear wheel unless I remove the QR nut, as the QR nut interferes with the RD. Having a direct mount hanger will solve that problem. The second benefit is weight savings. With DM hanger you only have one pivot bolt instead of two.
Look around you and see how fast everything is evolving, like the smart mobile phone you have. Then take a look at the bicycle which was invented over 100 years ago. In ten years your car will likely be totally autonomous :D
PostPosted: Wed Jul 26, 2017 10:13 pm
classic hangers put rd in different positions relative to wheel and chainstay, because classic hanger spec is not strict
dm hanger position rd in exact position where shimano spec wants it to be. only some of classic hanger position rd in the same spot,
this spot gives you best wheel removal and arguably may affect shifting (again, some classic hangers may put your rd in same spot with same effect)
PostPosted: Wed Jul 26, 2017 10:23 pm
Classic hanger specs do specify a range of workability however. Perhaps it's the new derailleur design as well, but the "latest and greatest" most certainly has not made wheel removal easier. Quite the contrary.
Colnago C60 - PR99
PostPosted: Wed Jul 26, 2017 10:33 pm
pdlpsher1 wrote:
...On my bike I can't remove the rear wheel unless I remove the QR nut, as the QR nut interferes with the RD. Having a direct mount hanger will solve that problem. The second benefit is weight savings. With DM hanger you only have one pivot bolt instead of two.
Ok, perhaps a DM hanger might help your specific problem, but your problem is a basic design flaw in your frame. I know exactly what you're talking about and those situations are an annoyance for sure, but not related to the DM issue. Any frame that requires you to remove your quick release skewer nut before you can remove the rear wheel is just a poor design from the get go.
Colnago C60 - PR99
PostPosted: Mon Jul 31, 2017 7:48 pm
ST-R8020 diagram uploaded (hydro brake + mechanical shift)
interesting details:
ST-R8020 and ST-R9120 uses same body design and same hoods design
(unlike ST-R8000 vs ST-R9100 - they have different body and hoods design)
Also, ultegra level WH-RS700-TL wheels added to Dealers manual::
http://si.shimano.com/pdfs/dm/DM-WH0002-10-ENG.pdf
File comment: ST-R8020
File comment: ST-R9120
PostPosted: Tue Aug 01, 2017 9:24 pm
ST-R8070 diagram uploaded (hydro brake + di2 shift)
again, ST-R8070 is copy-paste from ST-R9170 design/hoods
File comment: ST-R8070
File comment: ST-R9170
PostPosted: Wed Aug 02, 2017 5:40 pm
matty wrote:
197g
My front ring is 48T melon(Garbaruk), so its almost the same as 50T?
"Nothing compares to the simple pleasure of a bike ride"
Jamis Renegade Expert
Spark 900 RC
PostPosted: Wed Aug 02, 2017 5:56 pm
Has anyone posted the weight differences for the hydro di2 shifters from 9100 to 8000?
PostPosted: Mon Aug 14, 2017 12:35 pm
No pics of ST-R8070 & ST-R8020 with scale weight yet.
Shimano updated catalog weights, still look suspicious:
2017-07-01: ST-R8020 550/pair; ST-R9120 505/pair
2017-08-10: ST-R8020 554/pair; ST-R9120 538/pair
No changes about ST-R9170 360/pair & ST-R8070 360/pair,
but we already know that ST-R9170 real weight is 320/pair
Also updated catalog info on CS-HG800 cassette 11-34T:
2017-07-01: carbon spider 1, alu spider 1, weight 335
2017-08-10: carbon spider 0, alu spider 2, weight 335
PostPosted: Wed Aug 16, 2017 6:04 am
Just gotta love Shimano's product spec strategy... remember the WH 9100 C40 CL spec?
There are no new unread posts for this topic. Cervelo S5 due an update in 2018?
Shrike
Tue Apr 25, 2017 8:08 pm
Shrike View the latest post
There are no new unread posts for this topic. Attachment(s) PSA - B.O.R. German Sealant (UPDATE) - DO NOT BUY
possibleweenie
26
1909
Tue Nov 21, 2017 2:11 pm
eins4eins View the latest post
There are no new unread posts for this topic. MyCampy App crash after firmware update
tadrums
Sat Dec 24, 2016 2:07 am
tadrums View the latest post
There are no new unread posts for this topic. Bianchi Speciallisima 2017 update??
Conradsleight
Mon Jan 23, 2017 1:40 am
Conradsleight View the latest post
There are no new unread posts for this topic. Garmin 520 Firmware Update 12.1 and eTap
TarugoKing
10
964
Tue Aug 01, 2017 3:23 pm
wheelbuilder View the latest post
Users browsing this forum: Baidu [Spider], dualathlonpc, EvilEuro, Google [Bot], raisinberry777, TobinHatesYou and 23 guests
