Ultegra update?
madik
by madik
Any thoughts on R8000 availability? Specifially whether Ultegra di2 will start selling at the same time as mechanical? In DA case the mechanical version started to sell around October 2016 and di2 around Februrary/March 2017. Also the M8000 XT groupset in di2 was later than mechanical.
Have a feeling the scenarion will be the same with new Ultegra and we will have to wait longer for the di2 version..
Functionality > Performance > Weight
TyhpoonP
by TyhpoonP
It is expected
It's cheaper than the 9100 and the performance is likely to be similar
If Di2 is released, I think it's probably Team Kill ...
Daniel1975
by Daniel1975
You forgot to mention "it's more boring'.
slake21
by slake21
morrisond wrote:Let's hope they price new Ultegra cheaper than 6800 like they did with 9100 vs 9000 as well.
It will make a great cheaper option. 9100 just doesn't seem to be different enough any more.
I wish Shimano had made 9100 more special - finish it differently or put ceramics in it - even if you don't agree they are a worthy upgrade.
if it's gonna be cheap enough I might wait and get this instead of 9100.
there's a price where the new crankset doesn't seem that fugly after all.. :D
sungjinmo
by sungjinmo
I'm looking forward to seeing new ultegra!!
JasperGr
by JasperGr
Ultegra Di2 8000
Verzonden vanaf mijn iPhone met Tapatalk
chronsbons
by chronsbons
... ummm... that is 6870.
Reason: deleted the quote.
slake21
by slake21
chronsbons wrote:
JasperGr wrote:
Ultegra Di2 8000
yep
ooo
by ooo
11-34T cassette PDF published by shimano
http://si.shimano.com/#/en/search/Keywo ... S-HG800-11
11-13-15-17-19 cogs uses the same part numbers as CS-M8000 cogs
Y1RK11000 = 11T sprocket (same for 11-34T, 11-40T, 11-42T, 11-46T)
Y1RK13000 = 13T sprocket (same for 11-34T, 11-40T, 11-42T, 11-46T)
Y1RK15000 = 15T sprocket (same for 11-34T, 11-40T, 11-42T, 11-46T)
Y1RK17000 = 17T sprocket (same for 11-34T, 11-40T, 11-42T, 11-46T)
Y1RK19000 = 19T sprocket (same for 11-34T, 11-40T, 11-42T, 11-46T)
and next cogs are new combinations:
Y1WH98020 = cluster 21-23-25 (only 11-34T)
Y1WH98030 = cluster 27-30-34 (only 11-34T)
edit:link for ritxis
Ritxis
by Ritxis
ooo wrote:11-34T cassette PDF published by shimano
direct pdf link? thanks
ooo
by ooo
Ritxis
by Ritxis
ooo wrote:http://si.shimano.com/#/en/search/Keyword?name=CS-HG800-11
Thanks!
Ritxis
by Ritxis
Today in Barcelona presentation.............until June 8, prohibited to publish information
have made sign, confidentiality document
Bjobjo
by Bjobjo
Didn't you just publish information?
flying
by flying
Ritxis wrote:Today in Barcelona presentation.............until June 8,
I was about to buy a Compact FC-6800
Can you say if it will be for sale as of June 8th?
If so I may wait for this
Thanks
