How to wire up new Bar-End Junction A for Di2 (EW-RS910)
bikerdan
by bikerdan
I've picked up Dura Ace 9070 Di2 derailleurs and shifters while they are going cheap. Now I'd like to buy the cables too but I'm unsure on how you wire it up with the new bar end junction box when it comes out? Seen the first shops are now listing it...even if they don't have it yet
My Ultegra Di2 setup was pretty easy...2 x 250 to the junction box under the stem and then down to the bottom bracket. But with the new bar end junction box I'm guessing I'll need a short cable from the nearest shifter, a longer one from the other that travels over to the bar end and then a long one that goes from the bar end and then all the way back through the bars and off down the the BB ? Is that right ?
Haven't managed to find any diagrams showing this setup yet....
Ritxis
by Ritxis
The Shimano distributor for Spain, I commented that in December would be available all the information
hornedfrog
by hornedfrog
Shimano have actually made a new "Y" shaped e-tube wire that they are releasing with the new group. It is meant to make the shifter to junction box completely internal. Don't know if you are willing to drill holes in your bars right behind the shifters for the wires, but Shimano will also be making pre drilled bars within their Pro line of products.
bikerdan
by bikerdan
I've got look ADH bars and they have drillings in all the right places as far as I can see.
I saw the Y-cables but the shortest was listed as 50mm and that's too short from shifter to bar end. So I figured that was for satellite shifters
Guess I'll wait till more info is around
Sent from my MotoG3 using Tapatalk
hornedfrog
by hornedfrog
The 50mm was in reference to the single tail end of the wire that plugs into the junction box. It comes in three options: a 320mm/320mm/50mm y wire, a 520mm/320mm/50mm y wire and a 520mm/520mm/50mm wire.
wingguy
by wingguy
bikerdan wrote:the shortest was listed as 50mm and that's too short
So don't look at the shortest :lol:
mrlobber
by mrlobber
hornedfrog wrote:The 50mm was in reference to the single tail end of the wire that plugs into the junction box. It comes in three options: a 320mm/320mm/50mm y wire, a 520mm/320mm/50mm y wire and a 520mm/520mm/50mm wire.
What's the Shimano part number for these new wires? Can't seem to find them on Shimano website, only EW-SD50 all the time.
bikerdan
by bikerdan
ew-jc130
toiyuet
by toiyuet
Timujin
by Timujin
bikerdan wrote:I've picked up Dura Ace 9070 Di2 derailleurs and shifters while they are going cheap.
I havent seen a huge price drop yet.. where did you buy??
ooo
by ooo
I can't even find cheap batteries BT-BCR2 (replaced by BT-DN110)
sugarkane
by sugarkane
I make di2 Barend junction boxes... So the wire up is as follows
Replace your main cable from the bb with a 1400mm
Remove the 300 from the bars
Jumper the two top ports in the shifters with a 650mm cable via the internal ports
Then you need to wire your main cable with heat shrink via the internal ports to the second plug point on your rear brake side.. ( euro is right, Moto is left ) then the junction box gets the last spare port from the bar end via the intenternal rounding port..
Not very hard really
peted76
by peted76
sugarkane wrote:I make di2 Barend junction boxes... So the wire up is as follows
Dude, you say it and it sounds sorta easy, but when you're a dumb fool who cocks every bike project up 1st time like me... the thought of tearing the wiring fully out of my bike is frankly terrifying... I like a learning curve, but even basic electrics on a bike is too far beyond my comfort zone.
You should sell a 'wire' kit with some basic instructions and a bar end faceplate.. I'd buy it!
bikerdan
by bikerdan
Exactly the sort of info I was after
You make it sound easy
The one bit I don't understand is the "heat shrink the wire...". Do you mean shrink wrap tubing that contracts when you warm it up. Or doing something directly to the di2 cable.
I would have thought I could just plug it into the second port on the shifter
Sorry for the dumb question...
Delorre
by Delorre
I think he means to use shrink cable to 'bond' the brake cable and the main 1400mm wire from where it exits the frame until the rear brake leaver for a clean look.
