nvroadie
by nvroadie on Tue Nov 08, 2016 7:14 pm
glepore wrote:http://www.nashbar.com/bikes/ProductDisplay?storeId=10053&langId=-1&catalogId=10052&productId=591671&utm_source=Google_Product_Search&utm_medium=pla&utm_campaign=datafeed&cm_mmc=Google_Product_Search-_-PLA-_-Datafeed-_-PRO%20PLT%20Ergo%20Alloy%20Road%20Handlebar%20%2040Cm&CAWELAID=400006960000138177&source=googleUS&CAGPSPN=pla&CAAGID=25428001938&CATCI=pla-174916265778&catargetid=400006960000134410&cadevice=c&gclid=CjwKEAiAjIbBBRCitNvJ1o257WESJADpoUt081pBWJlrebm-lGdSuhGsmkWBXz2lkVaYl5wcHzCV3hoCxsvw_wcB
The PRO looks to be a little too heavy. Have you heard of the Fizik Cyrano R3 bars? They are claimed to be 245g in the 42cm! In the 38cm they would be around 230g.
nvroadie
glepore
by glepore on Tue Nov 08, 2016 9:20 pm
Looks like a winner, 7075 alu.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.
; Anvil Custom steel Etap;1996 Colnago Technos Record
PrimO
by PrimO on Wed Nov 09, 2016 12:13 pm
I have Deda Zero100 bars in 44cm and they weigh 252g.
38cm bars (although you need to get 40cm in if you want 38cm centre to centre) will be 15-20g less saving you almost 100g immediately.
nvroadie
by nvroadie on Wed Nov 09, 2016 3:57 pm
PrimO wrote:I have Deda Zero100 bars in 44cm and they weigh 252g.
What do you think of the stiffness of the Deda bars? Like the weight, but am worried about them being noodley.
tonichan
by tonichan on Wed Nov 09, 2016 4:40 pm
For brake try kcnc c7.its on ebay.it says 164gr rear n front.
Crank i use fsa slk light.its about 555gr.
For wheelset.i bought from fic bike.its on aliexpress.its only 890gr without skewers.
Im scale it using lugage scale.im not sure its real or not.but its look good for me
Sent from my E6683 using Tapatalk
nvroadie
by nvroadie on Sat Nov 12, 2016 3:49 pm
Update- I got the Cannondale Si crankset! The hole crankset (without chainrings) is 450g. The SRAM Force without chainrings weighed 520g. The next upgrade will be the bars, going to the Deda Zero100 in 40cm width, wich will save around 100g. And while I'm at it, I'll throw on a Kalloy Uno7 stem.
nvroadie
nvroadie
by nvroadie on Sun Nov 13, 2016 6:19 am
thencameyou wrote:fizik r3 bars weigh in at 248g in a 42cm c-c measurement FYI
Thanks, now I'm not sure which one to get. What do you think of the stiffness. I don't want to end up with a noodle that makes the handling odd.
nvroadie
nvroadie
by nvroadie on Sun Nov 13, 2016 6:24 am
thencameyou wrote:stiffness is absolutely fine, no discernible difference from the Deda model (I am no sprinter though, max power ~1000w)
No problem, I'm 58 kilos and have the upper body strength of a 2 year old. I'm not going to be able to flex either. How similar is the bend of the Deda to a FSA compact bend?
nvroadie
Svetty
