Northwave Extreme RR shoes 2017
Anyone seen or worn a pair of theses slipper's ?
Look good.. just wondering if there was any real feedback...
I'm using the extreme rr and also the xc for mtb, but the last year models. For 2017 I will definiatly get me a pair of those neon yellow 2017 RR's.
I like them a lot, as they fit my foot perfectly. In other shoes I always had the problem, that there was a lot of room over the instep and I couldn't get them tight enough for my liking. Not so with the Extremes.
Before I switched to NW I had a pair of s-works road shoes. After some months, the boa needed constant tightening during rides. It didn't need a lot of adjustments, not even a quarter of a turn, only a few mm. Maybe I'm finicky, but it was really annoying to me.
The Extremes are different. I tighten them and the tension doesn't reduce.
They are also super stiff, but I never put them on a scale.
Only negative for me: the release system of the boa closure. From other boa shoes, I'm used to lift the adjustment wheel or to turn it backwards to loosen them. The extremes have a small button you have to push (the small silver hook at the adjustment wheel) and sometimes, I can't get them off my feet as fast as I would like to.
Whats the sizing like on the Extreme RR's compared to Sidi's for example. I understand Northwave typically runs a little wider than Sidi but from what I've managed to find with some quick googling, lengths can/have varied in the past.
FWIW, I wear a 44 in Sidi's (wire/ergo/genius/dragon) and wore 44 Nike's when they made cycling shoes. I haven't had any luck finding a store with them in stock to try on/buy, so online it is
eins4eins wrote:I'm using the extreme rr.......
Push the button to loosen in small increments, pull the button to loosen in big increments. Pull and hold it to loosen completely.
I think it's a better system than the Boa left and right as the constant turning seems to wear them out quickly.
Rev wrote:Whats the sizing like on the Extreme RR's compared to Sidi's for example. I understand Northwave typically runs a little wider than Sidi but from what I've managed to find with some quick googling, lengths can/have varied in the past.
This is based on Northwave Extreme 44s. Specialized and Shimano 44s fit me but I had to go up to 45 when I tried on Sidi Wires.
I have been wanting them too they look like the shoe ive been waiting for but hate to order something wout being able to try on first, cant find them anywhere... Similar sizing to sidis? Am i understanding?
Sent from my HTC One_M8 using Tapatalk
My wallet is the lightest thing on my bike.
mrgray wrote:these look amazing.
agree, these look great!
Ok been on a pair now for a week or two .. very good. Nice fit and feel very stiff.
Glory Cycles UK site says you should go 1/2 size larger than Shimano or Fizik for these shoes- don't know if that is truly accurate. I wear a 46.5 in Shimano and I will order a 47 for these Northwave Extreme RR. I'll let you know how they fit when they arrive.
CampagnoloRules wrote:Glory Cycles UK site says you should go 1/2 size larger than Shimano or Fizik for these shoes- don't know if that is truly accurate. I wear a 46.5 in Shimano and I will order a 47 for these Northwave Extreme RR. I'll let you know how they fit when they arrive.
That's an odd advice as find shimano sizing very different to fizik
I guess it all depends on what you're used to. With new Fiziks I've gone 1/2 size smaller in the R1Bs than my usual sizing - so by extension I'd then assume that Northwave RR sizes are perfectly normal.
As always with shoes though, YMMV!
- milesthedog
Love those shoes! Is that dial made by Northwave? Any idea where it could be purchased on it's own (in bulk or a one-off)?
I've been in Simmons full custom carbon shoes for over a year now and swear by them - the comfort is just amazing. I can go out for all day rides with tons of climbing and my feet stay comfortable with no hot spots and they stay cool.
