Lighter di2 tt setup?
Raccooningtanuki
by Raccooningtanuki
Wouldn't it be lighter to pair sprint shifters with 3t brake levers instead of the di2 tt brake levers?
ms6073
by ms6073
Not possible with stock components. The Shimano SW-R610 sprint shifters have a keyed e-tube connector that fits in the bottom port of the ST-9070 shifters, where as SW-R671 TT shifters have built-in E-tube wires and no aux e-tube ports.
Rudi
by Rudi
You can use the "climbing" shifter straight into the A junction. The wire is a bit short so I had to mount the junction to one side to make it reach - on the bar itself rather than the traditional stem placement. If you are happy to solder 2 wires together to make the wire longer then that would reach. I was only using it for the RD so didn't need it in the middle.
I believe that would still be lighter overall and depending on what TT level you use, cheaper also than the dedicated Shimano tt brake lever.
Cervelo R3 - 5.4kg viewtopic.php?f=10&t=142420
Raccooningtanuki
by Raccooningtanuki
Rudi wrote:You can use the "climbing" shifter straight into the A junction. The wire is a bit short so I had to mount the junction to one side to make it reach - on the bar itself rather than the traditional stem placement. If you are happy to solder 2 wires together to make the wire longer then that would reach. I was only using it for the RD so didn't need it in the middle.
Climbing shifter is the same weight as a bar end. Or paired with a lightweight brake lever about the same weight as a tt STI. :|
Rudi
by Rudi
I think the Bar end shifters have to have the inserts to install them into the bars. The climbing one doesn't.
Internet weight says 313g per pair of the Di2 specific brakes, so 156g each.
I used planet X TT levers (internet weight 105g for the pair) and the climbing shifter is 30g (also internet weight), so I'd say lighter. I believe the Planet X levers weighed less, but I have the weights at home so will check later. Roughly just over half the weight?
Guess it will vary on how much the TT levers weigh though.
Edit: Still had a picture on my phone - 96g for the pair. 78g for 1 lever and climbing shifter.
Further edit: It isn't by any means as neat a solution as the standard Di2 lever, but it works and the question was about a lighter set up.
Raccooningtanuki
by Raccooningtanuki
Rudi wrote:I think the Bar end shifters have to have the inserts to install them into the bars. The climbing one doesn't.
Bike24 has climbing shifter listed at 79g, bar ends are about 75 each. A regular Ultegra di2 STI should only be about 150g though so possibly if you use a single regular di2 STI, a 3t brake lever on the other side, and then sprint shifters instead of bar ends you would be at around 250g vs near 450g. If that's electronically compatible...
