Specialized shiv tt handlebar extensions
Louie
by Louie
Hi just took ownership to a specialized shiv tt and was wondering is it possible to change the extensions on these (I prefer ski extentions).
audiojan
by audiojan
Yes, all you need to do is loosen the elbow pads, and the bolts compressing the extension brackets. Then of course you need to re-run all the wires in your new extensions, but that's not a big job. I bet the entire process takes you less than 1 hr.
cyclenutnz
by cyclenutnz
You need to order the Shiv TT Extension clamp mounts.
You remove the whole S-bend part and install the above mount that has a socket for you to fit any extension. So you can choose the angle you prefer, cut to length and install.
Louie
by Louie
Thanks for answering my question, follow up, where will I be able to purchase said device, no lbs is a dealer.
cyclenutnz
by cyclenutnz
ring a dealer in your country and ask them to order and send.
They're not easy to find otherwise. Don't expect the dealer to know what it is
