Best Winter Tires in 2016/2017
3Pio
by 3Pio
Thinking should i order winter tires, or just keep riding with Vittoria Corsa G+ 25mm...
So, On the fixie bike that im using for commuting, im using 25m Continental 4 Season, and except beeing not fastest and not beeing most comfortable tire, the grip and lasting is very good.
Is there any better Winter tire in 2016 then Continental 4Season? (Grip is most important, specially on Wet and frozen roades, then puncture protection then everything else)
Do u replace ur tires at all for Winter riding or u continue to ride with the regular tires?
Stueys
by Stueys
I run conti 4s in the winter and highly rate them, great grip in the wet and good puncture protection. However I don't commute and if there's an ice risk I find the turbo has a whole new level of appeal. For something for frozen roads I suspect something with studs on would be better, but I've no real experience or studs on tarmac, etc.
3Pio
by 3Pio
Stueys wrote:I run conti 4s in the winter and highly rate them, great grip in the wet and good puncture protection. However I don't commute and if there's an ice risk I find the turbo has a whole new level of appeal. For something for frozen roads I suspect something with studs on would be better, but I've no real experience or studs on tarmac, etc.
Turbo? What tires are those? I dont need with studs, just the tyre which rubber is optimized for colder climate (let's say from 0 degrees up to 10 degrees Celsius). I need this for my C60, because this winter i'll try to be as much outside as possible, and riding on trainer as less as possible :) Last winter i was riding with the Attack/Force combo, and on wet road i crash on the road from loosing grip (temperature was like 2-3 degrees Celsius). This injury keep me from bike 2 months, and pain in the arm for few months.. That's why im thinking to get proper winter rubber. Or what im getting for winter riding if i buy 4Seasons compared to Vittoria Corsa G+ (which i just installed).
cmcdonnell
by cmcdonnell
I wouldn't use the VIttorias as it would be a waste and they have next to no puncture protection; save them for summer. The Continental GP 4-seasons are a good tyre for cold wet (non-icy) tarmac but I prefer the Continental Grand Prix GT's. Been using them the last 2 winters and find them more comfortable than the 4-seasons, they roll better and they seem as robust too so a win win.
Bianchi Oltre XR2 + Campagnolo Super Record 11 + Campagnolo Bora 50C
Litespeed T1 + Campagnolo Chorus 11 + Campagnolo Shamal Ultra
kasperkls02
by kasperkls02
I think he means hometrainer or it is the S-Works Turbo which i use as summer tires
3Pio
by 3Pio
cmcdonnell wrote:I wouldn't use the VIttorias as it would be a waste and they have next to no puncture protection; save them for summer. The Continental GP 4-seasons are a good tyre for cold wet (non-icy) tarmac but I prefer the Continental Grand Prix GT's. Been using them the last 2 winters and find them more comfortable than the 4-seasons, they roll better and they seem as robust too so a win win.
The answer that im looking for :).. But im confused.. Are those GP 4 Season higher or lower ranged then Gt's? Is there any advantage of 4 Season compared to Gt's?
3Pio
by 3Pio
kasperkls02 wrote:Turbo? What tires are those?
Yeah.. Probably Turbo trainer :) i was confused a little bit, because i know the Specialized Turbo are summer tire
by Nefarious86
Conti GP 4 seasons.
Using Tapatalk
Rudi
by Rudi
If you like Vittoria then why not the Pave? I have commuted over the winter on them for the last couple of years and they have been fine for me. Still 25mm as well.
the blurb from a popular online retailer:
The clincher version of the Pavè CG tubular is hand-made and provides excellent grip and performance, thanks to the “open tubular” construction. It's a tyre well suited for Autumn/Winter riding both in wet and dry conditions.
I don't like conti (no real reason, I just don't) so can't really compare - sorry.
Cervelo R3 - 5.4kg viewtopic.php?f=10&t=142420
3Pio
by 3Pio
Rudi wrote:If you like Vittoria then why not the Pave? I have commuted over the winter on them for the last couple of years and they have been fine for me. Still 25mm as well.
Yes, i wanted Pave CG Clincer, but i could not find them on german retailers sites where i'll order them. Also im not seeing them on Vittoria site.. Maybe they are replaced with some of G+ tires and discontiuned?
Anyway, i just ordered 4 Season. Thanks a lot for everyone
RedCoke
by RedCoke
Good Choice. I did not use stub tires by myself, but many riders said 'waste of moeny = heavy + poor durability'
Lieblingsleguan
by Lieblingsleguan
Vittoria Pave rides a lot better than Conti 4S, but I had bad luck with multiple punctures on a single ride (not connected, different little stones and glass working their way through the rubber). So I changed back to Contis.
However, a lot of people had better luck and if you want to try it, Probikeshop has them in stock. I ordered there (also from Germany). It is discontinued by Vittoria, though.
fromtrektocolnago
by fromtrektocolnago
most important thing if its an option is to be riding with wider tires and lower pressure. a 32 mm tire @ 70 psi is less likely to have a flat than a 23 mm tire at 95 psi. then other things matter like a touring tire which will be thicker and more puncture resistant and has better traction.
Colnago C-59 (Dura Ace)
Firefly(Ultegra)
Colnago C-64 disc(ultegra) with Bora 35 wheels
Nejmann
by Nejmann
Seriously.. Durano DD in the winter.. Never had a flat in like 4 years.. And sexy tires in the summer..
mpulsiv
by mpulsiv
Strike through word "best" from your dictionary! There's no such thing. If you are looking for balanced winter tire for foul weather then look no further than Continental 4Season. It's as puncture resistant as Gatorskins (heavier and don't roll as well). Winter tires are far from supple. They key is run at low pressure. 80 psi max (25mm) and its irrelevant how much you weight.
