It is currently Mon Jan 22, 2018 3:39 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Thu Oct 27, 2016 6:03 pm
After searching this only references to Shimano were found. Those indicated it would work.
So, specifically does anyone have insight as to whether an 11 speed Campagnolo Record crank will work with a 9 speed chain?
This is all toward the end of completing a piece meal 11 speed upgrade from 9 speed.
Thanks.
PostPosted: Thu Oct 27, 2016 7:50 pm
A 9sp chain will certainly sit on the chainrings. One might wonder whether the front shifting will be affected by the slightly narrower spacing between the two chainrings with 9sp.
Perhaps you can run a 10sp chain on 9sp.
PostPosted: Thu Oct 27, 2016 8:20 pm
Good point regarding the (perhaps) narrower chainwheel spacing. That's my specific concern, not having an 11 speed crank to measure with a caliper to get a comparison.
I seem to recall from somewhere the pin length is the same with the side plates somehow making the difference.
PostPosted: Thu Oct 27, 2016 9:48 pm
With current 11sp, and an 11sp narrow chain, the chain just barely, and I mean barely, clears the pickup pins on the large chain ring when you're crossed (meaning small chain ring, small cog). I would think that a thicker chain would at a minimum make using at least the smallest two cogs while in the small chainring unworkable. You shouldn't really be crosschaining like that anyway. And I'd be a little leery of the front either throwing the chain or having it ride on top of the teeth of the smaller chainring for a while before settling in. Like @Miller was implying above, if the 10sp chain is narrower than a 9sp chain, then I'd be more inclined to try that. It would be a 'tweener kind of compromise. Better at the front I would expect, but not so narrow (11sp chain) that it may compromise shifting in the rear even further. It would be a compromise at best whichever way you go, but you'd just have to try it and see if it is acceptable to you... at least till you can get a completely compatible groupset.
Colnago C60 - PR99; Trek Koppenberg - Where Emonda and Domane Meet;
C59 Five Years Later
Trek Emonda SL Campagnolo SR; Special Colnago EPQ
PostPosted: Thu Oct 27, 2016 9:53 pm
Thank you. That's exactly the info I was in search of.
PostPosted: Fri Oct 28, 2016 7:39 am
use a 10 speed chain on an 11 speed chainset with 9 speed cogs and you will be fine. Done this before and it works.
www.thecycleclinic.co.uk
PostPosted: Fri Oct 28, 2016 9:09 am
More detail here about 'width' of chains.
http:/velonews.competitor.com/2016/01/bikes-and-tech/technical-faq/tech-faq-chain-width-explained-compatibility-queries-answered_392163
There are no new unread posts for this topic. Campagnolo 10 / 11 speed Compatability
Tricky1
Mon Sep 25, 2017 1:36 pm
adson View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo 11 speed using 34/50x11/36! Yes it can be done with PRE-2015 Athena LC Big Gears on Campagnolo 11 speed
colnagoaddict
16
1562
Mon Dec 18, 2017 8:49 pm
graeme_f_k View the latest post
There are no new unread posts for this topic. Campag 10 speed cassette with 11 speed chain?
campagowlo
Sat Dec 30, 2017 10:41 am
bikerjulio View the latest post
There are no new unread posts for this topic. 11 Speed on 9 speed crank set?
Willem
Sat Apr 22, 2017 4:13 am
Willem View the latest post
There are no new unread posts for this topic. Compatibility Question - 11 speed Crankset & 9 Speed running gear
pfnsht
13
766
Fri Aug 25, 2017 2:31 pm
goodboyr View the latest post
Users browsing this forum: Bing [Bot], bremerradkurier, Fiery, ianeire, nowords, zulu695 and 45 guests
