It is currently Thu Dec 14, 2017 10:11 pm
Post new topic  Reply to topic  [ 14 posts ]
 Post subject: Fenders for Aero Bike
PostPosted: Wed Oct 26, 2016 10:46 pm
Hello, I am converting my summer road bike into a winter/rain bike and I am having trouble in finding which full fender fits.
I've tried installing a set of SKS Bluemels but they won't slide in between the tire and caliper.
To give you an idea of the tolerances I am running Dura-Ace 9000 Calipers with 700x25" Gatorskins
Any suggestions would be greatly appreciated!
PostPosted: Wed Oct 26, 2016 10:57 pm
I've installed Crud Roadracer Mk2 fenders on an aero bike. They don't always work well with 25 tires, but they're able to mount with minimal frame/brake clearance. Every frame is a little different, so I can't make and promises, but that's where I'd start.
PostPosted: Thu Oct 27, 2016 12:23 am
Thanks, I've considered Crud Fenders but I've read that they are a bit flimsy.
Was thinking about SKS Race Blades or something made out of metal.
I've inquired with Portland designs but they won't clear..
PostPosted: Thu Oct 27, 2016 12:32 am
Don't waste your money...
There are some other options in here...
viewtopic.php?f=3&t=141962
My Titanium Bike And Photo Blog
viewtopic.php?f=10&t=140326&p=1246305#p1246304
PostPosted: Thu Oct 27, 2016 11:00 am
The new Crud Fenders MK3 are out, and they are quite an improvement on the previous ones!
Parlee Z-Zero Disc
Stinner Frameworks Ti
Speedvagen 2017
Independent Fabrication Crown Jewel TI
Felt IAFRD
Cannondale Super Evo Six 2017
Opencycle O-1.0
Open New UP 2017
Canyon Inflite 9.0 2015
PostPosted: Thu Oct 27, 2016 4:52 pm
Thanks! I'll look into them.
Would you happen to have a set on your bike? How is the rear clearance on the bottom seat tube and tire?
PostPosted: Thu Oct 27, 2016 4:58 pm
Dont have one on my bike as yet, but have seen them on a Canyon Aeroad and they fitted no problem with 25mm tires! From what I gather they fit up to 38mm tires!
Parlee Z-Zero Disc
Speedvagen 2017
Felt IAFRD
Opencycle O-1.0
Open New UP 2017
PostPosted: Thu Oct 27, 2016 5:14 pm
Another vote for new redesigned Crud MK3 fenders http://www.crudproducts.com/roadracer-mk3
:nospamhere:
PostPosted: Thu Oct 27, 2016 6:34 pm
Thanks I have 5MM clearence, the Crud MK3 2017 model may work
PostPosted: Thu Oct 27, 2016 7:07 pm
That Crud fender will just keep yourself dry, it is not nearly long enough to cover the rider behind you, and the back fender looks pretty unstable
my vote goes to the new race blade :)
https://www.bike-components.de/en/SKS/R ... 16-p46712/
PostPosted: Thu Oct 27, 2016 9:47 pm
No fenders are long enough to protect the rider behind you, that's why there's a product called buddyflaps http://buddyflaps.com/collection.htm
:nospamhere:
PostPosted: Fri Oct 28, 2016 6:43 am
Actually it is quite easy to get good fenders for a road bike, just buy two sets of Crud roadracers. You can then easily mix & match the parts so that both fenders go low enough. I have not yet installed any Crud mk3's, but with the older Mk2's that worked fine.
PostPosted: Fri Oct 28, 2016 7:48 am
What kind of frame do you have? There are so many different kinds. Some have caliper brake, direct mount, direct mount under BB, V brake and so on.... Makes a big difference regarding how it's possible to mount the fenders.
PostPosted: Fri Oct 28, 2016 9:09 pm
I use Crud Racer 2's on my HED VO4 with 23/24 m tyres. The front sits a bit far off the wheel due to the depth of the front fork, but I tend to train alone on it as it isa TT bike so no problem with spraying others. I also use them on a Spec Tarmac as a winter bike. No issues with 4 winters on the same set. 23 mm tyres on this.
There are no new unread posts for this topic. Aero bars on non aero race bike
gurk700
18
3734
Wed Dec 13, 2017 7:07 pm
TonyM View the latest post
There are no new unread posts for this topic. Factor One Aero bike. Anyone?
Noctiluxx
Mon Aug 14, 2017 2:55 pm
Noctiluxx View the latest post
There are no new unread posts for this topic. Which current aero bike still uses bb30?
alcatraz
7
792
Mon May 29, 2017 8:26 pm
mrlobber View the latest post
There are no new unread posts for this topic. Anyone building full custom aero bike?
wheelsONfire
Mon Feb 27, 2017 2:54 pm
Gehenna View the latest post
There are no new unread posts for this topic. Rotate saddle on aero road bike?
mrsparkle
Tue Oct 10, 2017 6:35 pm
BeeSeeBee View the latest post
Users browsing this forum: antonioiglesius, Calvaroz, kode54, MayhemSWE, PinaF8, sivan and 31 guests
