It is currently Fri Dec 15, 2017 7:41 am
Post new topic  Reply to topic  [ 43 posts ]  Go to page Previous 1 2 3
 Post subject: Re: WCB-R-081 build
PostPosted: Fri Mar 17, 2017 7:22 am
communication with their sales person has been very unhappy.
they insist that this has nothing to do with the quality issue, therefore i will have to pay for the shipment back and forth if i requested for exchange.
totally disappointed with workswell, now probably will sand down the surface myself and hope it wont crack
PostPosted: Sun May 28, 2017 7:07 am
Update:
now 6.52 kg/14.39 lbs
Changes :
swapped out generic expander for an extralite expander
swapped out the 3T stem for a Kalloy Uno.
swapped out the Rotor 3D+ for a pair SISL2s I found for a great price on ebay!!!
swapped out the carbon seat for a Selle Italia Superflow SLR with titanium rails
swapped all stem and all frame bolts (except for the seat post) out for titanium from toronto cycles
I've put about 2500 mile on this frame and and can confirm this is a nice, stiff ride and there is no flex at all (although I'm only 60kg). I love the way my build has turned out so far and am very happy with it. I don't think I'll be shopping for a new road frame anytime soon.
As far as weight savings I could probably change out the tape and update my stainless steel Speedplays to titanium. I don't think I want to sacrifice any comfort on the seat as I really like the Superflow SLR.
PostPosted: Wed Aug 02, 2017 3:23 pm
Hi,
i want to buy this workswell-frame, too. I'm 1,78 m, so what frame size should i take??
Thanks, Thorben
Gesendet von meinem SM-G850F mit Tapatalk
PostPosted: Wed Aug 02, 2017 4:10 pm
I don't know about this geometry. Recommended for my body height is Size 54, but it seems to small for me, because the Seat tube is only 50,5 cm...Image
PostPosted: Wed Aug 02, 2017 7:36 pm
Nobody??
PostPosted: Wed Aug 02, 2017 7:49 pm
Why would you care about Seat tube? the top tube slope down like most compact/semi-compact geometry thus seat tube is low.
it doesn't tell a thing. Compact Geometry will always have smaller seat tube for the same size.
check about compact geometry:(Giant TCR is extremely compact) https://www.youtube.com/watch?v=TsQ1PimjpaE
Check Stack and Reach man. Only those two values that matter.
i'm 5'6.5" (168.5cm) and using size 49 whereas they recommend me size 52. And it fit perfectly.
If i'm 170-175cm i'd consider between 52 and 54. 175-180cm definitely 54. Only if you are 180cm+ then 56 make a lot of sense.
PostPosted: Sat Sep 16, 2017 10:48 pm
Hello everyone, I'm really interested in frame WCB-R-081 but i'm not sure if it's possible to install the shimano ultegra Di2 internal batterie or must be the external one.
Could anyone tell me?
Thanks.
PostPosted: Sat Sep 16, 2017 11:54 pm
Ask Workswell, they've always been very helpful when I had questions
PostPosted: Sun Sep 17, 2017 2:35 pm
In the description says,DI2 battery is hidden in Down tube,
But I wonder where exactly.
Can anyone take a picture and show us?
I'll try to ask them about that,although In my opinion owners might know better than the salesperson.
PostPosted: Sun Oct 01, 2017 1:08 pm
There is no space in the downtube. I putted it in the seatpost.
PostPosted: Fri Oct 06, 2017 1:02 pm
So it's posible to install the battery inside it?
There's enough space, right?
PostPosted: Fri Oct 06, 2017 7:53 pm
Yes, no problem to install it inside, wrapped with bartape!
PostPosted: Sat Oct 07, 2017 2:23 pm
Thank you very much, now and knowing that it's possible to install the battery inside the seatpost, I'll look for the best price for the groupset.
There are no new unread posts for this topic. Pinarello F10 Build
Bridgeman
24
3092
Fri Dec 08, 2017 7:42 pm
TonyM View the latest post
There are no new unread posts for this topic. Time to build
Lukester
Thu Jan 05, 2017 11:38 pm
Lukester View the latest post
There are no new unread posts for this topic. My Custom Build
callumghilton
Sun Mar 05, 2017 5:54 pm
kode54 View the latest post
There are no new unread posts for this topic. aluminum ww build
Rubik
Fri Jul 07, 2017 5:09 pm
HeluvaSkier View the latest post
There are no new unread posts for this topic. Help with budget sub 5k build
martinfrias
Fri Oct 06, 2017 9:26 pm
charlieboy52000 View the latest post
Users browsing this forum: Chris3g, Google [Bot], ksolar, MagicShite, mopin and 41 guests
