It is currently Wed Jan 17, 2018 11:17 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page 1 2 Next
PostPosted: Wed Oct 19, 2016 6:41 pm
Recently purchased for a project (I will post on that separately).
Advertised as 151.6g on ebay. Actual weight on my scales 164g. This is for a 400mm seatpost so still pretty light for that length and not very expensive.
I removed 8.5cm resulting in a loss of 23g. This was a conservative "checking the fit" cut. So 2.7g per cm (for this sample of 1) for those interested in the potential savings.
Second cut has removed another 6g so total weight now 135g for 293mm.
Not done a lot of kms so far so no review as such. Seems pretty sturdy is all I can say so far.
Cervelo R3 - 5.4kg viewtopic.php?f=10&t=142420
PostPosted: Thu Oct 20, 2016 12:54 am
Thanks for the review & weight!
Is there a specific vendor on eBay that sells Hylix?
PostPosted: Thu Oct 20, 2016 3:19 am
The cradle looks different from my Hylix seatpost. @Rudi, can you weight it and measure distance between rail recesses? I had a problem fitting chinese romin-like saddle, the cradle was too narrow and I've snapped rails off the shell.
Hongfu FM079 (6.72 kg)
PostPosted: Thu Oct 20, 2016 8:33 am
@djel I bought from liukang1985, have bout a couple of other things from them as well. Very happy with their service.
@Klaster1 it is on a bike at the moment, I can take it off and weigh separately but not right now. Is your carbon or metal? There is another version of the same post advertised at 176g. I think the only difference is that cradle. I've had no issue size wise with this and tried 2 different saddles.
PostPosted: Thu Oct 20, 2016 10:53 am
@Rudi, here's my cradle.
PostPosted: Thu Oct 20, 2016 2:04 pm
I'm not sure these are the same parts
Mine appears straight between the two sides (in red) where yours has some shaping.
Looks like you can still see the mold imprint on mine where as yours seems smoother there (in green).
Most compelling is the area in white. Mine is a small section of clamp where as yours appears to be open all the way to the other side.
edit - also just noticed the size of the holes in the centre are quite different as well.
Did you get it from the same vendor and when? I bought this maybe 2 months ago.
Not sure that helps you at all though.
PostPosted: Thu Oct 20, 2016 4:29 pm
Mine's from lan28033, seatposts listed in his store have cradles different from your's indeed. What's even more strange is that all liukang1985 seatpost listings show my type of cradle. Your cradle is being sold by him as a J&L product. I think it was replaced for some reason.
PostPosted: Wed Jan 11, 2017 8:39 am
http://www.ebay.co.uk/itm/301853613606
How likely is this to impale me in a freak accident haha
Using Tapatalk
PostPosted: Wed Jan 11, 2017 11:09 am
I bought a hylix stem from liukang1985 and I had a problem with threads stripping even at the correct torque.
He did however respond to every email quickly and send me a replacement stem.
As far as eBay sellers who sell weight weenie style products go I'd definitely use him. A very honest seller.
PostPosted: Wed Jan 11, 2017 7:02 pm
Online
Just received mine today. 31,6 and setbackImage
PostPosted: Wed Jan 11, 2017 7:42 pm
/\ weight?
PostPosted: Wed Jan 11, 2017 8:17 pm
Online
Actual weight 182 gram 31,6 mm / 400mm setback. Claimed seller weight was 180 gram
PostPosted: Wed Jan 11, 2017 8:35 pm
Bought the 27.2 400mm for a mountain bike and cracked it at the seat collar on the second ride.
PostPosted: Mon Jan 23, 2017 5:47 pm
^ was it torqued to spec? Warranty replacement/feedback?
grind it out
PostPosted: Sat Apr 22, 2017 1:45 am
Are the clamps on this particular Hylix post safe for use with typical 7x9 carbon rails?
There are no new unread posts for this topic. How to remove logos on Hylix carbon seatpost
stripes
Sat Mar 04, 2017 3:14 pm
evan326 View the latest post
There are no new unread posts for this topic. Giant D-Fuse Seatpost Weights
michael1984
Wed Sep 20, 2017 8:02 am
baaahwur View the latest post
There are no new unread posts for this topic. Best carbon seatpost for a 2016 Evo?
chadm
Sun Jul 23, 2017 2:31 am
chadm View the latest post
There are no new unread posts for this topic. seatpost for bontrager 7x10 carbon rails
hoojammyflip
Fri Feb 17, 2017 4:59 am
nickf View the latest post
There are no new unread posts for this topic. tightening asian carbon seatpost clamp
nrsnow
Mon Apr 10, 2017 7:26 pm
stockae92 View the latest post
Users browsing this forum: 3Pio, AZR3, Geordiepaul, mortirolo, Yahoo [Bot], Zakalwe and 36 guests
