It is currently Tue Jan 16, 2018 8:38 pm
Post new topic  Reply to topic  [ 15 posts ]
 Post subject: Lightest +/- 10 deg stem
PostPosted: Sun Oct 16, 2016 7:11 pm
As the title implies. There was a thread with the same title 7 years ago so it's not exactly useful these days.
Easton EA90-146g
Pro Vibe- 135, new version is claimed at 120g.
Thomson X2- Clamp issues sketch me out, 131g.
Any other better options? I know Extralite does -12.
Gramz
Failed Custom Bike
PostPosted: Sun Oct 16, 2016 7:18 pm
Yes, Extralite Hyperstem (+-12 degrees) is the lighter one, just 79 grams in size 100
My 5,02 kg Supersix Evo HM: http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=137647&start=30
My 6,22 kg Cannondale R500 1996: http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134364
PostPosted: Sun Oct 16, 2016 8:46 pm
Last gen Pro 7s weighs 144g for 130mm. I would not recommend the Extralite stem for you. My experience is that it's flexy enough to negatively influence bike handling (e.g. descending in a straight line, causing wobble).
Strava
Current Stable. The Snob Machine | The Crumpton
The Ex's. LS Siena: 6.21kg | Parlee Z5 SLi: 5.9kg | LS Xicon: 5.76kg | C59: 5.7kg | Cervelo R5ca: 5.09kg | Fuji Altamira SE - 6.2kg | Scott Foil - 6.2kg | Evo - 5.18kg | LS Classic - 6.7kg
PostPosted: Sun Oct 16, 2016 9:04 pm
130mm Pro Vibe 7s Puzzle Clamp: 146g including bolts.
Colnago C60 - PR99; C59 Five Years Later; My Special Colnago EPQ
Trek Emonda SL Campagnolo SR; Trek Koppenberg - Where Emonda and Domane Meet
PostPosted: Sun Oct 16, 2016 10:54 pm
why do you list the Easton EA90 which is aluminum while there is Easton EC90 being carbon and weight 110g (that maybe the weight of shorter size, i don't really know)
amazon's link is just for option listing, showing that there are 0 degree and 10 degree
https://www.amazon.com/Easton-SM1056-P- ... th=1&psc=1
PostPosted: Mon Oct 17, 2016 12:09 am
The EC90 is a pretty ugly stem and doesn't look good on any of the bikes I've seen it on.
PostPosted: Mon Oct 17, 2016 2:52 am
Weird, a guy I know races pro and WC XC and has used the new Hyperstem with 0 issues. Another friend has them on his road bikes and at 170lbs said he didn't notice much. Was this the older version?
I need a 110 or 120 and it'll go on my Epic WC
EC90 isn't an option as its fugly and not that much lighter.
Gramz
Failed Custom Bike
PostPosted: Mon Oct 17, 2016 3:01 am
I had the Road OC stem. Above 40mph on a straight descent the bike would become darty. I got rid of the Xicon because of that. After the C59 was already on the way, I got a Zipp SL stem to swap in and found out the problem went away with the new stem. The newer version is less stiff fwiw.
Strava
PostPosted: Mon Oct 17, 2016 5:13 am
I had been told that the new version (aside from FWB's test) was stiffer. Never heard of such a problem.
Gramz
Failed Custom Bike
PostPosted: Mon Oct 17, 2016 8:23 am
I think there is more of a problem with your front end than stem stiffness, stem stiffness would not cause a speed wobble,......fork steerers are more flexy than stems..
Btw I have an extralite -12 hyperstem, it is very light and stiff enough.
PostPosted: Mon Oct 17, 2016 3:01 pm
That's what I figured and why I got rid of the Xicon. Speed wobble is the wrong word, becoming darty is more appropriate. My last ride on the Xicon I put on the Zipp SL stem and did a 50+ mph descent and it was rock stable.
@kwalker, make sure you get the revised one that doesn't bite into the fork steerer. If you get one, let us know how it goes since you're going to be more of a demanding user than the typical purchaser. On the other hand, the amount of weight placed on the stem is a lot higher on road so it may not be noticeable on XC.
Strava
PostPosted: Mon Oct 17, 2016 7:11 pm
Read this :)
http://blog.fairwheelbikes.com/reviews- ... em-review/
PostPosted: Tue Oct 18, 2016 4:36 pm
What clamp issues?
.....but it still has to work!
PostPosted: Tue Oct 18, 2016 4:52 pm
Lots of cracked faceplates over the years.
Gramz
Failed Custom Bike
PostPosted: Tue Oct 18, 2016 7:41 pm
Not to derail. But I don't think Thomson has much of that problem anymore. Personally I think a lot of cracked faceplates was due to people running carbon bars, no carbon paste, and to prevent bar slippage would over torque the bolts. I run an X2 on my bike, haven't cracked a faceplate yet and I'm not particularly easy on my bikes. But definitely not the lightest stem out there nor the stiffest.
Sent from my SAMSUNG-SM-G930A using Tapatalk
There are no new unread posts for this topic. Lightest adjustable stem
LouisN
Mon Aug 28, 2017 2:06 pm
LouisN View the latest post
There are no new unread posts for this topic. Lightest 38cm stem/bar combo
jpshorts
Mon Jan 15, 2018 10:37 pm
jpshorts View the latest post
There are no new unread posts for this topic. Lightest Stem with 40mm Steerer Clamp
Lelandjt
9
589
Thu Dec 07, 2017 8:44 pm
stormur View the latest post
There are no new unread posts for this topic. Lightest aero base bar + stem combo? (separate or integrated)
alcatraz
Fri Aug 18, 2017 10:52 am
Juanmoretime View the latest post
There are no new unread posts for this topic. Lightest Saddles For Clydledales?
tabl10s
7
963
Thu Aug 31, 2017 9:40 am
jemima View the latest post
Users browsing this forum: Baidu [Spider], Flasher, Malammik, ride1970, sun and 40 guests
cron
