It is currently Wed Jan 17, 2018 4:33 am
PostPosted: Sat Oct 15, 2016 6:42 pm
Hi,
On my cannondale supersix hi mod 2014 the rear brake cable is sticking, as in the lever has free play and you can push the brake caliper apart, I've changed the brake cable and housing and the problem does go away for a month or two but comes back. The entry point for the rear brake at the headtube seems to be at an awkward angle for entry and not optimal for brake usage. Has anyone come up with a solution for this? It's a size 56cm as I see on the smaller sizes they had a different routing with a sram red aerolink brake.
PostPosted: Sun Oct 16, 2016 11:26 am
I had similar problems with my CAAD and found some photos online of some mods the Garmin mechanics were using to get around it. Ultimately you need to use a more flexible section of brake outer where the brake cable enters the head tube, whether that be a section of the flexi outer that Jagwire supply for use at the hoods, 5 or 6 nokon links, or even a flexi v-brake noodle.
I started with the nokon links and still wasn't that happy with the angle the cable was taking in to the head tube, I've since gone to the flexi v-brake noodle and I'm much happier with it now. I'll be doing the same to my Evo when I next change brake cables
PostPosted: Sun Oct 16, 2016 2:03 pm
Yeah, I am really annoyed by the cable routing for the rear brake on my supersix. Can't say I am familiar with the brake getting sticky, my expectation would be that the little cable in the rear is gritty, but you already changed that so it should be ok.
Have you tried taking the brake apart and lubing it? The fact that new cables is only a temporary fix for you indicates that there is a bigger issue than just sticky cables. On most bikes the rear brake gets covered in grime, gets sluggish and heavy.
Sent from mTalk
PostPosted: Sun Oct 16, 2016 5:32 pm
Hi,
Thanks for the replies. I like the idea of the flexible brake noodle, didn't know these things existed so I might purchase one and see how it goes. Seen this, http://www.chainreactioncycles.com/bran ... prod138559, that should do the ticket nicely but says it's only got 18 degrees of movement, I'm needing probably around 90 as the bend is that tight when it enters the headtube. Do you know of any others that might work?
Kurets, I'm inclined to agree with you on the point it could be something else but when I've pulled it all apart and cleaned everything slips and slides wonderfully, seems to be when you turn the handlebar the angle of the cable routing messes up the brake cable and it's tension.
Kind regards,
Simon
PostPosted: Sun Oct 16, 2016 7:09 pm
Full Nokon works well on mine
PostPosted: Mon Oct 17, 2016 2:57 am
Simon430 wrote:
Hi,
Thats exactly what I've used on the CAAD, I just cut the nipple end off to insert the noodle in to the frame
PostPosted: Mon Oct 17, 2016 10:43 am
Wouldn't the noodle just slip into the frame if you don't have the end cap on? No cable stop for the brake cable to be pulled against?
PostPosted: Mon Oct 17, 2016 5:17 pm
The cable stop is built into the head tube.
PostPosted: Mon Oct 24, 2016 4:52 am
Sort of, it is removable.
PostPosted: Mon Oct 24, 2016 4:55 am
This is also an issue on my 2015 CAAD10, one which I haven't solved to my satisfaction yet. Currently I'm using an ultra stiff brake outer made by Goodrich. Makes turning the bars a little sluggish though but is working (for now).
There are no new unread posts for this topic. Attachment(s) Routing rear brake cable
Lightweenie
19
907
Wed Nov 29, 2017 10:27 am
Fiery View the latest post
There are no new unread posts for this topic. C60: rear brake cable in the top tube
TonyM
Sat Sep 16, 2017 6:52 pm
Zakalwe View the latest post
There are no new unread posts for this topic. Caad12 rear brake guide missing?
Nejmann
Sun Sep 10, 2017 2:08 am
TarugoKing View the latest post
There are no new unread posts for this topic. SRAM Red rear brake caliper problem
itguy
Wed Jan 10, 2018 12:41 am
itguy View the latest post
There are no new unread posts for this topic. Can a Campy Record 10-speed rear brake/shift unit be converted to
Catagory6
13
665
Wed Sep 27, 2017 1:09 am
bikerjulio View the latest post
Users browsing this forum: Baidu [Spider], rcb78, spandexboy817, wheelbuilder, woodnat1, Wookski, Yahoo [Bot] and 29 guests
cron
