It is currently Wed Oct 18, 2017 3:31 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Fri Oct 14, 2016 9:35 am
I m looking to purchase a Caad 12 frame and move my SRAM RED22, Enve Cockpit and all other parts over from another bike. However my current bike has a SRAM Black Back GXP Ceramic Cup BB and comes with a SRM Power Meter S975 GXP Compact.
Could somebody please advise on what is the best way to do this. I know Praxis Work do a PRAXIS CONVERSION BOTTOM BRACKET, a CONV BB-SRAM™/GXP™ ISIS2 ROAD BB Size 68mm.
Is this the correct one? Or are there any other ones on the market? Better ones? Ceramic Ones?
Thanks in advance!
Parlee Z-Zero Disc
Stinner Frameworks Ti
Cannondale Super Evo Six 2017
Speedvagen 2017
Independent Fabrication Crown Jewel TI
Opencycle O-1.0
Felt IAFRD
Canyon Inflite 9.0 2015
PostPosted: Fri Oct 14, 2016 10:01 am
Praxis has a good all-in-one solution. It's somewhat heavy, but very reliable. However, I'm not sure it'll work with BB30A. It's for BB30/PF30 only. [edit] It's not compatible.
C-bear has a similar product, which is specifically for BB30A.
https://www.c-bear.com/en/products/bott ... e-sram-gxp
You can order C-bear directly from them simply by sending them an email. They ship really fast.
Another option is adapters which fit into you current bearings, but that's far from ideal (risk of creaking noises is large).
http://wheelsmfg.com/bottom-brackets/ca ... vativ.html
Most "innovations" in cycling are solutions for non-existing problems.
PostPosted: Fri Oct 14, 2016 10:09 am
Is the C-Bear better than the Praxis one? It seems the C-Bear is a Ceramic one as well?
If adapaters creak than I rather stay away from there, as it will drive me insane! :)
havana wrote:
Praxis has a good all-in-one solution. It's somewhat heavy, but very reliable. However, I'm not sure i'll work with BB30A. It's for BB30/PF30 only. [edit] It's not compatible.
Parlee Z-Zero Disc
Speedvagen 2017
Opencycle O-1.0
Felt IAFRD
PostPosted: Fri Oct 14, 2016 10:15 am
C-bear = ceramic. Quality is outstanding.
Praxis will not fit.
PostPosted: Fri Oct 14, 2016 10:49 am
I used the Wheels Manufacturing adapters this summer and they seemed to work very well (installed by Condor with lock tight). Not a great year for me though so although they were ridden in all weather they didn't do more than a couple of thousand miles.
PostPosted: Fri Oct 14, 2016 12:59 pm
What about the standard headset it comes with! Is that fine or should I upgrade! As I m buying it as a frame set!
Parlee Z-Zero Disc
Speedvagen 2017
Opencycle O-1.0
Felt IAFRD
PostPosted: Fri Oct 14, 2016 2:31 pm
Nothing wrong with the headset. If you maintain it properly it will last longer than the bike. Make sure you put lots of marine grease on the lower bearing. Repeat this proces at least once a season.
The dimensions are quite specific; only the original will fit.
There are no new unread posts for this topic. Caad12 help
raffit78
Thu Jun 01, 2017 3:00 am
are View the latest post
There are no new unread posts for this topic. BB30 circlips when fitting BB30-24mm Bottom Bracket
thepainandsuffering
Mon Oct 16, 2017 1:26 pm
hambini View the latest post
There are no new unread posts for this topic. CAAD12 headset
tomee
Fri Feb 03, 2017 1:58 am
tomee View the latest post
There are no new unread posts for this topic. CAAD12 for climbing?
superdx
33
5647
Sat Mar 11, 2017 1:59 am
MisterMuncher View the latest post
There are no new unread posts for this topic. Supersix Evo vs CAAD12
Thenuge
25
3616
Sat Oct 07, 2017 11:54 am
Peperami View the latest post
Users browsing this forum: Baidu [Spider], cyclenutnz, GMF, Google [Bot], kurisu, Yahoo [Bot] and 20 guests
