Problem with Shimano S-Phyre road shoes, loose cleat nut
jimaizumi
by jimaizumi
Would it be possible to have a photo posted here so that we can get a visual understanding? While I've seen these in the flesh, I'm trying to grasp what I can try to do if I naively decide to lift a pair...
THE PAST: 2005 C'dale R700, 2006 Spesh S-Works Tarmac Gerolsteiner, 2009 Pinarello Dogma FPX My Way, 2011 Time RXR VIP
THE PRESENT: 2016 Colnago C60 ST01, 2017 Wilier Cento 10 Ramato, Cinelli Gazetta
THE FUTURE: :mrgreen: :mrgreen:
by Nefarious86
//uploads.tapatalk-cdn.com/2016112 ... eca067.jpg
2016 SWorks cleat nut may also work.
Reason: removed the img tags.
Using Tapatalk
fordred
by fordred
The shoes come with 2 rubbers per nut that prevents that cleat nut from moving right?
Here's a pic from mine.
It's raining here almost everyday so I've only wore it once, but did not encounter any issues with the cleat moving.
kkibbler
by kkibbler
These look perfect and only cost a few cents each but cost a fortune to ship to me. If you're in the US, please PM me!! Thanks.
M5 double tab weld nut
http://www.jhpfasteners.com/0.80-double ... -l-en.html
upside
by upside
Those rubber plugs allow you to move the cleat more rearward or forward.
goodboyr
by goodboyr
Looks like exactly the same design as the older top end Shimano road shoes......and I've never had this issue with them....so what's the difference?
Sent from my SM-G900W8 using Tapatalk
spud
by spud
kkibbler wrote:These look perfect and only cost a few cents each but cost a fortune to ship to me. If you're in the US, please PM me!! Thanks.
Have you tried McMaster Carr? They might ship a bit more cost effectively
kkibbler
by kkibbler
I couldn't find these on M-C, and last I checked they don't ship outside of the US anymore.
goodboyr
by goodboyr
Did you have those red spacers installed when you torqued the cleat bolts?
jeffy
by jeffy
^ the red spacers are (can be) removed to have a more forward/rearward cleat position.
goodboyr
by goodboyr
jeffy wrote:^ the red spacers are (can be) removed to have a more forward/rearward cleat position.
Nope......
http://si.shimano.com/php/download.php?file=pdf/um/SI-0164A-000-ENG.pdf
kkibbler
by kkibbler
@gooboyr: are you asking me or the other poster with the slipping cleats? If you're asking me then no I did not remove them when I torqued down the cleat bolts. I don't see how they could make any difference on the issue I had.
goodboyr
by goodboyr
I was asking you. Theory was that the spacers would prevent the nut from pulling down through the sole due to too much torque. But since you didn't remove them I guess that's out the window.
mattr
by mattr
The nuts aren't pulling down, they are spinning.
From what i can see of these spacers, they'll make no difference anyway.
