CAAD 10 Bottom Bracket
FastPants
by FastPants
HELP.....
Just bought a CAAD10 frameset which has had an English Thread BB conversion :(
I don't want to risk having the conversion removed but wondered if its possible to still fit a Rotor BB30 crank by using external cups or similar? :noidea:
by Nefarious86
Conversion? Pics?
Using Tapatalk
CamW
by CamW
I'd be surprised if it was that tricky to remove. But should you really be averse to it rotor makes the following BB for BSA frames: http://rotorbike.com/catalog/default/ro ... -30-1.html
FastPants
by FastPants
:beerchug: most excellent ... Sir you are a star
ihs0yz
by ihs0yz
It'll be a lot unnecessary weight you're carrying around! I actually had a CAAD10 converted to BSA with a SRAM adaptor and it was a REALLY tight fit. LBS told me it'd be best if nobody tried removing it..
FastPants
by FastPants
The adaptor appears to be aluminium so I hope not too heavy and I have ordered the Rotor BB30 cups which I hope will do the trick as I want to install a 3D+ crank
