It is currently Sun Oct 22, 2017 1:29 pm
PostPosted: Thu Oct 06, 2016 4:56 pm
Does anyone have any experience with this post?
Good/bad points? In particular, how securely does it clamp the saddle?
Finally, I have never used a carbon seatpost before. Every time I ride, I pick my bike (about 9kg fully loaded) up by the nose of the saddle and take it down a flight of stairs, and then back up again at the end of the ride - will a lightweight carbon seatpost be able to handle this?
Thanks in advance!
PostPosted: Thu Oct 06, 2016 7:49 pm
I've got about 1200 miles on my EL post without any issues. No issues with saddles slipping or moving at all, I've had similar style seatposts and they all clamped the saddles rails securely.
As far as carrying the bike by the nose, I can't see any problems with that, riding would bring about more issues than just picking your bike up by the nose.
PostPosted: Fri Oct 07, 2016 6:41 am
Thanks for the feedback @AZR3 - just what I was after!
PostPosted: Fri Oct 07, 2016 11:31 am
sib you are concerned about the weight of 9kg of weight hanging from a saddle and seatpost then are presumably going to rest your delicate man bits on that same saddle/seatpost in addition to presumably 70+ kg of weight and ride at speed on presumably less than mirror smooth roads?
PostPosted: Fri Oct 07, 2016 11:23 pm
why would you worry about carbon fibre it is an very tough material. millions of people ride arround on carbon fibre frames and forks wheels e.t.c and you are worried that somehow you might break it by picking up the bike by the saddle.
if you worry about that then dont ride your bike, as riding is a more hazzordous activity. I have one of the posts by the way un rideen as of yet but I am not worried either.
www.thecycleclinic.co.uk
PostPosted: Sun Oct 09, 2016 5:32 am
I have Woodman products, although not the EL post, and the quality of the parts is always top notch.
PostPosted: Sun Oct 09, 2016 11:21 pm
Compatible with oval carbon rails?
PostPosted: Mon Oct 10, 2016 3:32 am
Top and bottom clamping posts have no issue with oval rails as the width of rail is no different from the top or bottom. Side clamping posts can have issues or require different clamps in the event of oval rails
There are no new unread posts for this topic. Best carbon seatpost for a 2016 Evo?
chadm
Sun Jul 23, 2017 2:31 am
chadm View the latest post
There are no new unread posts for this topic. Cutting a carbon seatpost
MattSparkes
23
4984
Fri Jul 07, 2017 3:47 pm
youngs_modulus View the latest post
There are no new unread posts for this topic. seatpost for bontrager 7x10 carbon rails
hoojammyflip
Fri Feb 17, 2017 4:59 am
nickf View the latest post
There are no new unread posts for this topic. tightening asian carbon seatpost clamp
nrsnow
Mon Apr 10, 2017 7:26 pm
stockae92 View the latest post
There are no new unread posts for this topic. How to remove logos on Hylix carbon seatpost
stripes
Sat Mar 04, 2017 3:14 pm
evan326 View the latest post
Users browsing this forum: alorast, Baidu [Spider], Bing [Bot], Erwin, Google [Bot], Google Adsense [Bot], jlok, jobvisser, Lewn777, simplemind, uraz and 26 guests
