Scale Shots Thread - Component Weights with Pictures (Use this for Search: SSTCWP)
RyanH
by RyanH
Before I get flamed, yes we have the listings section; however, I prefer to see scale shots so I know what is being included in the weight. I end up trying to google scale shots of things, and almost always to no avail. I also think it'd be easier for people to post their photos here than someone explain to everyone that they can, and should, be posting to the listings section. In order to make this thread useful, it should be searchable using the search feature. Putting that little code in the title should do just that.
How to search for weights in this thread
1.) Go to search
2.) Search for Keywords: +SSTCWP itemname
3.) Under Search in Forums: Select Road
4.) Leave everything else as is and press search.
Format of this thread should be adhered to (welcome to suggestions):
Item Name, Model Year & Category (e.g. stem, seatpost)
Weight in grams
Notes (if applicable, such as "Weight with bearings")
Example:
SRAM Red Quarq 130BCD 2015 Crankset
760g
Notes: 175 arms, GXP, SRAM Red Yaw 53/39 Rings and alloy chainring bolts
Strava
RyanH
by RyanH
2014 Extralite UltraStar Expander
7g
eeBrakes 2015 Brakes
173g
Notes: Includes all hardware, even extra hardware
Fibre-Lyte 2015 Carbon 53/39 Chainrings Lightweight 2
81g
THM Fibulas 2014 Brakes
141g
Notes: All hardware needed except pads
THM m3 SRM PowerMeter Crankset 110 BCD 2015
459g
Notes: crank arms, spindle, spider, spacers and lock ring. Basically everything except the chainrings and bolts.
Berk Padded Lupina Saddle 130 width 2015
94g
Notes: Round rails
Strava
RyanH
by RyanH
Fibre-Lyte Carbon Chainrings 2015 110BCD 50/34 Lightweight2
74g
Strava
