bremerradkurier
by bremerradkurier on Tue Oct 04, 2016 6:55 pm
eric01 wrote:Shimano dura ace. Comes in drillings down to 24 h front and rear.
Not record but slap a 11speed shimano cassette on and it will work with 11 speed record.
Or use an Ambrosio conversion cassette with Shimano splines and Campy spacing.
Miller
by Miller on Tue Oct 04, 2016 7:47 pm
StradaJon wrote:We don't see a lot of demand for Campagnolo Record hubs. They are ok but hampered by being available in 32 hole only. Plus the QRs are of poor quality in comparison to the Shimano DA ones for example.
What's wrong with the Campag QRs? I think they're fab with a solid close that grabs the dropouts.
It's a shame that Campag hubs aren't available other than 32h but I guess Campag want to sell complete wheels, not hubs.
pressed001
by pressed001 on Mon Oct 10, 2016 6:45 pm
I've got some 7700 hubs and love them. Every 18 months or so I re-grease them (4000km) and the cones are still in great shape. The last time I did not install new bearings, probably not a bad idea for me to do.
Calnago
- In Memoriam
by Calnago on Mon Oct 10, 2016 6:53 pm
One of the great things about high quality cup and cone hubs is that if they eventually do develop a bit of play, that play can be easily adjusted out and good as new. So long as the bearings are not pitted etc., you can get some really long life out of them. Some might even argue smoother over time. Just periodically clean them up and regrease and they spin like new with no play for a long long time.
Once cartridge bearings develop play, you have no choice but to replace them.
ultimobici
- in the industry
by ultimobici on Tue Oct 11, 2016 9:33 pm
StradaJon wrote:The Campagnolo Record QRs look cheap compared to the DA ones side by side to a purchaser.
I disagree. They work perfectly for the money. A Dura Ace rear retails for more than the Record pair and, importantly for WW, the Record are lighter to boot!
The skewers work perfectly. I have never had any issue at all. If your customers turn their noses up at the skewers then they don't understand Campagnolo and probably want the freehub swapping out to HG11!
StradaJon
- in the industry
by StradaJon on Fri Oct 14, 2016 8:57 pm
Neither DA or Record QRs are lightweights are they, some of my customers are requiring a light build and these beefy chaps are not helping to keep the weight down.
We have a fair number of Campagnolo builds through the workshop but they just don't want or feel it is appropriate to fit 32 hole Record hubs on their bikes.
I don't think loose hub sales are a priority for Campagnolo hence the 32 hole pair.
pressed001
by pressed001 on Tue Jun 26, 2018 10:07 pm
I am about to build another wheel-set and have decided on either DA 9000 or a NOS HB-7900. The 7900 would be better for my build as it is a 3x10 speed 7800 group which looks gorgeous on the bike.
FWIW fulcrum CULT hubs are also amazing but you would need to buy a wheel-set as they require use of their special aluminum straight-pull spokes. I have serviced a few pairs of Zero's (1's also come with the same hubs) and the outcome was superior to that of DA with steel balls IMO. Never tried the DA's with ceramic balls though. Would be interesting to see the outcome.
The CULT hubs are also super easy to service and exchange of the cups and cones is simple. I always just exchanged the cones as those wear out faster than the cups. Especially if someone over-tightens the adjustment washer.
