Specialized S-works road crankset (2017) weight
Checking in on 2017 S-Works users: has anybody fitted one on a true PF30 frame (not a Specialized), ideally with a power meter?
On the old (2016 and before) version, you needed to dremel the lock ring down somewhat and use different spacers, otherwise it came into contact with the bearing cups.
No longer in the industry
Pretty definitely not - axle is too short.
@elfuinha: did you get a manual with the crankset? Wondering which side the preload adjuster goes on - I would assume on the non-drive side, and whether to fit any micro spacers on the drive side.
jever98 wrote:Pretty definitely not - axle is too short.
On the PFBB30 if i'm not mistaken just a 2,5mm spacer, the preload doesn't fit on the drive side there is no spacer.
when fitted the crank didn't spin...
I'm using XD-15 ceramic torqtite from ENDURO as the BB.
For those who installed the new 2017 crankset with the carbon spider on an SL5 sworks, are you guys using the bearing dust covers along with the preload adjuster as directed on the instructions? I read somewhere earlier someoone was foregoing the preload adjuster and using a wave washer and 3mm spacer instead?
Does anyone know the torque spec for the 2017 S-works crankarms? I now have two sets but I can't find the recommended torque spec for the new style crankarms. I know the old style was 33n/m with the specail tool... no I can't find any manuals on the new arms anywhere And the manual Specialized put in the box with the new arms is actually the pre-2017 manual). The arms spin freely around 15-20n/m but if I get up to 30n/m they seems to be more drag. Installs are in a sworks shiv and sworks venge both with the pressfit specd bearings. Thx much.
Reviving an old thread. Does anyone have a pdf or a scan of the instructions for the 2017 model? Bought one used and want to check on the conical ring and spacer setup. Searched all over internet and I can only find instructions for the previous gen model. Have also read that some folks have ditched the conical ring and went with a wavy washer?
I don't have the manual anymore, but if memory serves the conical ring went on the NDS and you use it to set the preload. I use a wavy washer instead, it gives a bit more space and allows use with a power meter on a PF30 frame
