It is currently Sat Dec 16, 2017 8:41 am
 Post subject: Bent derailleur cage?
PostPosted: Sat Sep 24, 2016 2:34 pm
A few weeks ago I had a crash with my Canyon Aeroad, unfortunately landed on the drive side so the majority of the impact was taken by the rear derailleur and the right brifter both got as bit scuffed but nothing major the only part i replaced was the derailleur hanger which cracked. I did get the new derailleur hanger aligned at the local repair shop so I am 100% sure that the hanger is perfectly straight.
http://imgur.com/a/Oqxst
Upon further inspection the lower jockey wheel seem to be bent outwards, what makes this a mystery to me is that there are obvious scuff marks on the parallelogram of the RD while the cage has no signs of impact, but then again if the whole derailleur is somehow bent and not just the cage then both the TOP and the bottom jockey wheels would have been out of alignment and the top jockey wheel isn't misaligned which I've visually checked (not sure if it's visible in the photos).
My question is: would it be smart to remove the derailleur and take the cage off to try and bend it back? I'm asking this because there are no signs of shifting problems, what I am worried about though is that somehow the chain will slip off the lower jockey and get stuck which can can cause all sorts of problems.
Cheers!
PostPosted: Sat Sep 24, 2016 5:17 pm
If the shifting is working good, with no signs of missing shifts or hick ups i would leave it as it is.
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
PostPosted: Sat Sep 24, 2016 9:34 pm
My 6536gr TIME Skylon
My 9733gr COLNAGO Master X-light
PostPosted: Wed Mar 29, 2017 10:00 pm
Resurrecting this slightly older thread because I noticed the same thing with my new Shimano Ultegra Di2 6800 series rear derailleur. Unlike the OP, it has never been down. But it looks a little tilted, bent or twisted outwards from the wheel. Is this by design, read normal for the rear mech?
Here's a photo:
PostPosted: Wed Mar 29, 2017 10:16 pm
Is the derailleur hanger straight? A lot of these aren't straight out of the box.
PostPosted: Thu Mar 30, 2017 2:26 pm
@NiFTY, I can confirm that the derailleur hanger is straight. Using the Park Tool, I straightened the new hanger before installing the new RD. It really is the craziest thing. Considering that the top chain guide wheel on the RD is directly under the cassette gear, the bottom chain guide wheel, and thus cage, looks looks twisted. I wondered if it was because Shimano want it tilted well away from the spokes. I should admit that shifting is reasonably fine.
PostPosted: Thu Mar 30, 2017 10:21 pm
Thats weird. I would leave it rather than try and bend the cage straight if its shifting fine.
PostPosted: Fri Mar 31, 2017 11:34 am
That cage definately looks bent to me...
If you look at the outer plate, it looks bowed out, which would make the lower pulley wheel stick outwards just like it does.
You don't need to have gone down to bend the cage. If the chain has ever gotten caught or wrapped around the casette or you have backpedaled before completing a shift it's possible that you have pulled the cage all the way forwards and bent it.
There are no new unread posts for this topic. How to decide what to replace in a bent rear derailleur
nemeseri
Mon Aug 07, 2017 9:04 am
MayhemSWE View the latest post
There are no new unread posts for this topic. Medium cage on pre-2017 campy derailleur
joeyb1000
Sat Sep 16, 2017 3:35 pm
joeyb1000 View the latest post
There are no new unread posts for this topic. Short vs Medium Cage Rear Derailleur
jma6610
21
1719
Thu Dec 14, 2017 7:52 pm
Mr.Gib View the latest post
There are no new unread posts for this topic. Ultegra 6800 long cage rear derailleur indexing issues
alcatraz
Fri Aug 18, 2017 1:17 pm
WinterRider View the latest post
There are no new unread posts for this topic. Attachment(s) New Chorus RD....bent??
Boshk
27
1319
Thu Oct 12, 2017 2:42 am
Boshk View the latest post
Users browsing this forum: Bing [Bot], nemeseri, psycling, TobinHatesYou, Yahoo [Bot], zefs and 34 guests
